Old 05-06-2016, 09:10 PM   #1
erikforce1
erikforce1 is an unknown quantity at this point
s13 Rear axles binding feel
Hey guys. So I was installing my axles after installing my lsd and now my axles feel like they're binding and they have no shaft play. It was really hard to get my axles in. In order for me to install my axles, I had to disconnect my rear camber and caster arm. The binding feeling is the same as if the parking brake is on(which it's not).
My setup in my 91 s13 coupe is:
Tomei 1.5 LSD
ISR adjustable arms
KYB AGX w/ Eibach lowering springs
Z32 brake conversion
Is there something I missed? Any help will be appreciated!
erikforce1 is offline   Reply With Quote
Old 05-08-2016, 07:38 AM   #2
erikforce1
Update: problem solved.
For some odd reason the parking brake shoes got tight so I backed them out a bit.
