s14 5speed swap
i swapped my 240 to a 5 speed only concern i have is the driveshaft where it meets up with the tranny it looks like the dust cover is rubbing the tranny. i could be wrong but idk how close its supposed to be since this is my first 5speed s14. I bought the driveshaft from a non abs s14 so i dont see how there could be any length issues as mine is also non abs s14. any ideas. I wont really be able to do anything till the morning but ill take suggestions now.
![]() Join Date: Dec 2002
If it's rubbing on only the dust cover, remove and throw away the cover. If it's rubbing on the tail shaft end of the transmission you have a problem.
Any ideas of how this problem would happen assuming im using the correct shaft? This is the best shot i could get of it tonight ill take one from underneath when i can see in the morning.
