91 240sx w/ s13 blacktop sr20det
192,090 miles on body
sr20det blacktop about 40,000 miles runs strong apexi gt spec downpipe 75-85-90mm 3" flex/midpipe apexi gt spec exhaust apexi n1 coilovers 32way koyo radiator fal fans ebay intercooler polyurethane tranny mount nismo coppermix unsprung clutch kit this clutch sells for $1600 and is amazing new slave cylinder the car is a little beat up on the driver side but is a perfect canidate for overfenders there is no frame rust, but has a hole starting in engine bay under brake master cylinder like most 240s i have other parts for this car thet i can sell seperate as well: origin doors with all factory mounting points for door panels and window motor $600 and full kazama under carage consisting of tie rods,tie rod ends, tension rods, rear subframe collars, rear upper control arms, rear traction rods, and rear toe links $1200 pm me 5000 obo for car |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
is it a clean title with no wrecks? if you want it gone, i could do 5500 for everything, and i live in des moines iowa, so i think i could probably come get it? maybe its too far, let me look it up
everything is still available thanks for the offers of trades but i really need the cash fellas so anyone look for a good track car with all the expensive bits out of the way send me a pm thanks
#15 | ||||
460
| doors, s13, sr20det, suspension, turbo |
