South Western States Arizona, California, Hawaii, and Nevada. |
03-11-2006, 12:33 AM | #1 |
alarm help...in LA area
im trying to install a viper 791vx into my 240...lol i never done alarms at all...and i figured it would be easy but >.< there are soo many wiresss....i looked over the manual and there are a few wires that i dont know where it goes.... if someone can come over and help me out that would be cool =) pm me if you can
-thanks |
03-12-2006, 07:32 PM | #3 | |
note: many wires do not need to be connected |
03-13-2006, 01:06 AM | #4 |
i use to install alarms at circuit city. so maybe i can help. dont got much time but i can tell u where they go....What are the wires called that u are stumped on???on alarms ALOT of the wires are not needed cause they are options.
03-13-2006, 01:11 AM | #5 |
03-20-2006, 02:38 PM | #6 |
o man... i tried reading the wiring diagram but im illiterate or something because i dont know what most of them mean =( can someone help tell me where what goes
thoes are the 3 main diagrams i need help on =( here is a wiring diagram for my car i found btw: i have a 93 240 if that helps 12volts white ignition harness Starter black/white ignition harness Second Starter black/yellow ignition harness Ignition black/red ignition harness Accessory blue ignition harness Power Lock orange/black driver kick panel Power Unlock same wire Parking Lights red/blue back of dash dimmer Head lamps Green/Yellow L And Green/Blue R at Steering Column Door Trigger red/white courtesy light Trunk/Hatch Pin red sw. or light in trunk Tachometer yellow/red ECM pass. kick panel Brake Wire red/green brake pedal switch Horn Trigger green/white steering column |
