![]() Join Date: Mar 2011
Q45 tb can I use different tps??
Hi I got a q45 tb my tps can loose and belt ate it long story short someone ran it over I need new one can’t find any junk yards is there any tps from any other nissans I can use ?
![]() Join Date: Jun 2003
Trader Rating: (129)
I mean as long as it provides the same 0-5v output, over the same number of degrees, and physically bolts up. . . .
Update you can use the 91-93 tps for the q45 Tb u will have to set it full turn to get in spec but that just makes it easy because it’s all the way so there’s no playing around adjusting it
