![]() Join Date: Mar 2008
![]() Feedback Score: 21 reviews
S14 Parts, Z32 rear brakes, Z32 BMC, etc..
Some parts I have left over after selling my car. All items are shippable. Will require shipping fees and paypal 3% fees.
Complete Z32 Rear brake upgrade. Comes with BNIB Z32 Slotted Rotors, Z32 rear calipers with pads, Z32 Splash Shield with Drum Brake, R33 Cables - $450 S14 KA Intake Cam with Sprocket - $25 Z32 TT ebrake cables for s13 drivers who want to use the splice method - $20 S14 Zenki '96 grill $30 Centric Z32 Aftermarket 1" BMC Brand New. Took it out of the box to check and see if there was a fitting under the allen but there was not - $70 ONLY ONE Z32 Aluminum Front Caliper (Passenger Side) 26mm - $50 S13 KA24 Intake Bent where it mounts to radiator shroud - $40 S14 Knock-off Vertex Front Bumper Split in half - $30 S14 Knock-off DMAX Roof Wing. Needs work fitting. - $80 SR20 T25 (a little play but all I am under the impression that all journal bearing turbos do that unless pressured by oil?) - $100 370cc SR20 Injectors I can't find to take pictures but will upload - $50 Will update with more parts as I find them. Have a couple more lying around. |
Also have s14 headlights for 120. Bump. Pm me if you want something. Haven't been receiving emails for posts on the thread
Also have nismo black aluminum shift knob. $50 Oh and everything obo Last edited by iamtheyi; 09-17-2014 at 09:24 AM.. |
![]() Join Date: Jun 2004
Trader Rating: (73)
If you do not have ABS, you will need to remove the plug from the second front brake line port, illustrated below. If you have ABS, you do not have to remove the plug. In that case, skip to the master cylinder installation. Typically, a standard allen tool will be more than adequate to remove the plug. In some cases, it appears that remanufactured master cylinders have a 5 sided allen plug. You will need to find a way to remove the plug possibly using an undersized 6-sided allen tool.
#20 |
