06-04-2008, 07:42 AM | #1 |
Os Giken Super Single (sr)
hey everyone i just purchased a used clutch. got the rebuild kit for it. now im just curious what Throw Out Bearing that is required for the OS Giken super single clutch for the s13 SR20det.
i dont want to ghetto rig it, shits gotta be done right. just curious is everyone has ever used it, opinions overall and which TOB to use? thanks in advance.
Banana boat chronicles |
06-04-2008, 07:46 AM | #2 |
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
06-04-2008, 07:51 AM | #4 |
cuz the OS Giken uses a longer collar and the bearing is differnt
I have a twin plate so I know I posted a pic of the difference between OEM and The OS Giken one in another thread
06-04-2008, 07:53 AM | #5 |
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
Yep, with most plate clutches like that, you need the manufacturer's TOB. I have an ORC Single, and it uses the ORC bearing, and it's quite different from the OEM one.
06-04-2008, 07:54 AM | #6 |
alright. but, what if my super single is different.
im looking for people that have used this exact clutch before. twin plate is a bit different from single
06-04-2008, 07:59 AM | #7 |
well it more than likely thinner
regardless OEM will not work properly for the OSGiken I did an Install on a twin plate using the OEM Collar but Used the OS Giken Bearing, The clutch did not disengage completely even with ajusting the MC rod, becuase the collar was differnt so with a Single more than likely it wont disengage at all You have to use the OS Giken Bearing the contact point for the Pressure plate smaller So if you use a OEM bearing you will more than like break the PP Fingers or the collar
06-04-2008, 08:05 AM | #8 |
domo.(thanks)
ill research some more and see how it goes. thanks for the 1 minute man response too
06-04-2008, 08:09 AM | #9 |
http://osgiken.net/products/racingmultiplate.html
os says that you can run a nissan tob. it comes off an early nissan truck. here is the part number. 30502-14601 here is the p/n for the sleeve. 30501-N1600 |
06-04-2008, 08:13 AM | #10 | |
I was reffering to not being able to use the OEM SR
