Old 06-27-2010, 09:00 PM   #1
s14koukirules
s14koukirules's Avatar
s14koukirules is an unknown quantity at this point
s14 oil pan removal
i have a 1995 s14 ka24de and i want to change my oil pan gasket because is leaking oil, i want to know how to get my oil pan out, what parts do i need to remove in order to remove oil pan and if some has some pics on how to remove my oil pan it will be very helpful.TANK YOU
s14koukirules is offline   Reply With Quote
Old 06-27-2010, 09:30 PM   #2
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
PM me your email and I'll send you the "engine mechanical" portion of the FSM. It's all in there.
khilgers is offline   Reply With Quote
Old 06-27-2010, 10:49 PM   #3
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
google 240sx oil pan tutorial or whatever you need to repair on 240sx
www.ka-t.org :: View topic - How to: S13 Oil pan removal
surreybc is offline   Reply With Quote
Old 06-27-2010, 11:03 PM   #4
n8RPS13
n8RPS13's Avatar
n8RPS13 is an unknown quantity at this point
Easiest way is to unbolt your motor mounts and lift your motor with a cherry picker unbolt your oil pan and then slide it forward. Then hard part is to get it back on without messing up your bead of fresh RTV. This is how I did it in my S13 so it shouldnt be to much different GL
WASTED I AM!
n8RPS13 is offline   Reply With Quote
Old 06-27-2010, 11:58 PM   #5
s14koukirules
s14
thanks for the info heres my email [email protected]
Old 06-28-2010, 12:40 PM   #6
projectRDM
projectRDM's Avatar
Way easier to drop the crossmember, just unbolt the steering rack and LCAs, place a bottle jack under the transmission bellhousing, and remove the crossmember entirely. Gives you all the room in the World to drop and reinstall the pan.
FORMERLY R240NA
Old 06-28-2010, 01:21 PM   #7
Jonnie Fraz
Jonnie Fraz's Avatar
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Send a message via AIM to Jonnie Fraz
Quoted for the truth! Way easier to do the cross member.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 07-01-2010, 12:21 AM   #8
greenzenki86
greenzenki86's Avatar
greenzenki86 is an unknown quantity at this point
crossmember is the best way....sorry but the guy up top who said to pull your motor out has gotta be fuckin kidding lol
Who cares if you have 800hp......
greenzenki86 is offline   Reply With Quote
Old 07-01-2010, 12:08 PM   #9
projectRDM
projectRDM's Avatar
Try reading better.
He didn't say to take the engine out. His comment was to lift the engine slightly, to gain clearance underneath. Which works fine if you have a hoist, but is still not the easier route.
FORMERLY R240NA
Old 07-01-2010, 12:20 PM   #10
The High & Mighty
The High & Mighty's Avatar
Trader Rating: (41)
The High & Mighty will become famous soon enoughThe High & Mighty will become famous soon enoughThe High & Mighty will become famous soon enoughThe High & Mighty will become famous soon enoughThe High & Mighty will become famous soon enough
Feedback Score: 41 reviews
you need a:
ratchet
air ratchet (optional, makes the job quicker)
10mm socket
razor blades ( to clean the old gasket off)
Angle grinder with a scotch brite pad ( optional, cleans the old gasket off quicker
Permatex The right stuff, gray import version (excellent gasket maker)
or
toyotas FIPG , works very well too.
loosen up the motor mounts from the crossmember. lower the crossmember a bit to get clearance to remove the oil pan. i believe the crossmember nuts are 17mm. support the engine either with a cherry picker or some jack stands. if you know anyone with one of those engine support bars used for fwd vechicle when doing a trans job, that will come in very handy.
Good luck with your task
The High & Mighty is offline   Reply With Quote
Old 07-01-2010, 12:22 PM   #11
greenzenki86
Try reading better.
ooooooooooooooooooooooooh, thats still too much for someone who is new imo....
Old 07-02-2010, 11:28 AM   #12
s14unimog
s14unimog's Avatar
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Send a message via AIM to s14unimog
And dropping the crossmember isn't? I lifted the engine to remove mine. If Russ say's you'll get more room, then you will, and you should go that route.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
