![]() Join Date: Sep 2010
Trader Rating: (41)
![]() Feedback Score: 41 reviews
Trying to clean-out my shop a bit and make room for new mad tyte jdm drift parts overnighted from Japan! I know the rules state that the thread needs pictures, or it will be deleted... I'm not going to take pictures of every part here. Please PM me if you're seriously interested in an item.
S13 PARTS: KA24DE exhaust manifold $10 KA24DE pressure plate & clutch $40 KA24DE Purolator oil filter $2 S13 KA24DE alternator $40 S13 KA24DE starter $30 S13 4lug front rotors $20 S13 glove box door $5 S13 hatch cargo cover $20 S13 bottom carrier bushing cover $2 S13 KA24DE fuel pump $20 S13 KA24DE complete intake manifold, throttle body, sensors & coolant hoses $50 S13 a/c control panel $10 S13 KA24DE MAF sensor $50 CXracing KA24DE cold air intake pipe $40 S13 SOHC gauge cluster SOLD S13 KA24DE distributor $40 S13 KA24DE transmission with sensors & mount $150 2.5" headerback factory style exhaust for S13 $50 S13 chuki front bumper (white) $40 Cusco 6pt bolt-in cage for S13 hatchback SOLD S14 PARTS: S14 zenki (95/96) front bumper lenses & bulbs $40 S14 radiator $40 S14 5lug rear brake covers $20 S14 5lug rear rotors (need to be turned) $20 S14 hood hinges $20 S14 rear caliper brackets $10 S14 right right caliper & e-brake bracket $20 S14 white face gauge cluster $35 S14 washer bottle resevoir $5 S14 zenki (95/96) Silvia grill SOLD S14 kouki (97/98) Autech grill rep $40 S14 a/c condensor $30 3" catback Apexi style exhaust for S14 $100 S14 rear bumper (white) $50 Final Konnexion S14 kouki 20mm front overfenders $250 SR20DET PARTS: KA/SR shifter, rubber boot & trim ring $30 SR/KA motor mounts $20 Competition Clutch stage 4 6 puck clutch 60442-0620 SOLD Circuit Sports 3" downpipe with cat delete $80 Megan Racing 3" test pipe SOLD S13 SR20DET power steering pump & bracket SOLD Five-0 850cc high impedence injectors (side feed) SOLD T25/T28 turbo outlet gasket $5 S13 SR20DET valve cover $45 S14 SR20DET a/c compressor, bracket & cut hardlines $50 SR20DET manifold heatshield $5 SR20DET factory catch can $5 S14 SR20DET factory pullies $5 CXracing SR20DET cold air intake pipe $20 Circuit Sports S13 SR20DET fuel rail $100 S13 SR20DET complete a/c setup SOLD S13 SR20DET fuel rail, regulator & injectors $80 SR20DET coil packs $20 each SR20DET ignitor chip $65 RANDOM: S-chassis "skinny" o2 sensor $20 HID ballasts & wiring (no bulbs) $20 Z32 e-brake brackets & 1 brake soft/hardline $5 Z32 26mm 4 piston front calipers $150 Walbro 255 fuel pump $50 HKS 1 1/4" boost gauge (bar) $40 AutoMeter oil pressure gauge (100psi) $30 Q45 dual piston front brake calipers & brackets SOLD RoadRaceEngineering catch can $30 s-chassis pocket din $10 Turbonetics Deltagate3 wastegate $50 S-chassis power steering resevoir $5 Z32 e-brake cables $25 S-chassis "fat" o2 sensor SOLD MOMO bucket seat $200 Sunpro boost gauge $10 Z32 front & rear staggers rims (2 have tires) $150 MAF sensor 40F00 $75 MAF sensor 69F01 $100 MAF sensor 52F00 $75 1991 Nissan 240sx S13 hatch shell for sale/trade Parting out KA24DE engine Just trying to clear out the shop a little bit. Prices do not include shipping, notice that I am located in Summerville, SC. I can post pictures of items as you request them if you're seriously interested. Will take trades for other s-chassis parts/rims. I can get pictures upon request, just ask me. If you don't like the price then throw me your offer. Thanks I DO NOT WANT TO SHIP LARGE/HEAVY ITEMS. I can get pictures upon request, just ask me. If you don't like the price then throw me your offer. Thanks I DO NOT WANT TO SHIP LARGE/HEAVY ITEMS. Complete S13 SR20DET a/c system: S13 Cusco cage: S14 gauge cluster: Turbonetics wastegate: S13 SR20DET Circuit Sports fuel rail: RRE catch can: Last edited by NickIsAZero; 10-05-2011 at 12:29 PM.. |
[QUOTE=
Factory S-chassis pocket din - $10 [/QUOTE] Hey i'll take this for sure, pm with shipping to NS, Canada.
Officer> "Is that Steering Wheel on the Right side because you moved it!?" |
Trader Rating: (41)
Literally everything you need inside the engine bay, I think I even have a belt for it. A/C compressor, bracket, lines, condensor, etc... I'll have to work out something for the shipping on that if you're interested.
#23 |
Trader Rating: (41)
No, but I do have a stock one sitting in the shop if you're interested... I'd really just like to get rid of the whole longblock. Had a rod knock, but still ran (oil filter loosened up, lost all oil & was continued to be driven). Asking $200 for it, still has all the accessories & everything on it.
#24 |
![]() Join Date: Jun 2011
I thought the ac stuff didn't fit inside an s13 with a sr20det swap? If it really does work I might take that off you later this week if still available.
#25 |
Trader Rating: (41)
One of the lines was modified to work. This is a complete, working, bolt-on a/c setup for a S13 with a SR20det swap. It was pulled from a running car and will bolt into yours just the same.
