Old 06-26-2012, 10:54 PM   #1
1992s13hatch
1992s13hatch is an unknown quantity at this point
Question sr20det boost solenoid help !!!??
I am doing a s13 Sr20det swap into my s13 and my motor didn't come with a boost solenoid will I be ok without it or do I need it I am buying a manual boost controller soon ?????
1992s13hatch is offline   Reply With Quote
Old 06-26-2012, 11:00 PM   #2
Sileighty_85
Sileighty_85's Avatar
just run a dedicated vac line to the Waste gate and you'll be fine
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-26-2012, 11:05 PM   #3
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Boost solenoid will give you 11.5psi if hooked up properly, otherwise you will get the standard 7psi.
Old 06-26-2012, 11:05 PM   #4
1992s13hatch
From the boost controller sorry this is my first turbo build
Old 06-26-2012, 11:15 PM   #5
1992s13hatch
So your saying I don't have to have it it just gives me more psi ?
Old 06-26-2012, 11:18 PM   #6
1992s13hatch
To the waste gate from the manual controller ?
Old 06-26-2012, 11:42 PM   #7
cotbu
cotbu's Avatar
Off to a great start!
He means bypass the solenoid, run a direct line to the wastegate!
If you want to increase boost, follow the instructions that come with said boost controller.
Old 06-27-2012, 12:26 PM   #8
mr2gons14
mr2gons14's Avatar
mr2gons14 is an unknown quantity at this point
haha ull catch on man srs are pretty easy to figure out at least the basics
zilvia.net/f/cars-sale/517359-95-240sx-sr20-swap-uras-greddy-apexi-ect.html
mr2gons14 is offline   Reply With Quote
Old 06-27-2012, 12:35 PM   #9
1992s13hatch
Yea just going to take a little bit
Old 06-27-2012, 12:40 PM   #10
kikcaffine
kikcaffine is an unknown quantity at this point
This.
Thats using the factory unit I presume your talking about? The only way though it will work is if the engine see no faults, if you run the diagnostics on your ecu and it pulls up ANYTHING it will not let it run the higher boost. If its all clear you will run the 11-12psi. Theres a guy on here selling one for like 20$ with the mounting bracket. Snatch that up.
kikcaffine is offline   Reply With Quote
Old 11-15-2012, 11:02 PM   #11
VinceDude
VinceDude's Avatar
VinceDude is an unknown quantity at this point
So do you need the solenoid if you have a boost controller or does the controller take the place of this solenoid? Also I thought running the solenoid would give you stock boost and running without it will increase this.
Edit: Can I run the wastegate vac line directly to one of the TB vac ports or does it really have to be on a nipple on the coldpipe(i don't see the difference between either cause they're right next to each other lol)?
VinceDude is offline   Reply With Quote
Old 11-16-2012, 08:28 PM   #12
cotbu
cotbu's Avatar
You do not need the oem boost solenoid. You can run any boost controller you want, boost will not be controlled by the ecu.
Doesn't matter then does it?
Old 11-16-2012, 10:47 PM   #13
VinceDude
VinceDude's Avatar
sounds good! Just wanted to make sure before I mess something up lol.
