Old 01-27-2010, 09:41 PM   #1
240ez
240ez's Avatar
240ez is an unknown quantity at this point
RB Rb still wont start..
My rb20t still will not start. I turn the key and it only gives one click. (All electricals work in the car)
I have a brand new Braille Battery (11lbs, 904 pca's)
Could it be my starter solenoid??
Need advice.
240ez is offline   Reply With Quote
Old 01-27-2010, 10:11 PM   #2
idamaster
idamaster's Avatar
idamaster is an unknown quantity at this point
I get this when the line to my starter gets disconnected from vibrations. Make sure the starter is connected.
idamaster is offline   Reply With Quote
Old 01-27-2010, 11:30 PM   #3
240ez
240ez's Avatar
RB
Yep the starter is connected.
Old 01-28-2010, 01:38 AM   #4
240ez
240ez's Avatar
RB
The starter is connected, but it still clicks once when i turn the key.
Old 01-28-2010, 05:13 AM   #5
eh?
eh? is an unknown quantity at this point
Take the starter off and have it checked at autozone or wherever they do it. Make sure your power and ground wires are in good shape.
eh? is offline   Reply With Quote
Old 01-28-2010, 06:56 AM   #6
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
i concur, check power supply cable, make sure battery's fully charged. make sure you have enough grounds.
if your car was previously an automatic did you bypass the park/neutral switch?
make sure your slave cylinder bolts aren't too long and keeping your clutch from spinning, you can use a 27mm socket on the crank pully and spin the motor over by hand clockwise.
you should be able to swap in a KA starter solenoid if everything else checks good.
gl man
Dave @ Pro Auto Care
770-980-0033
RB25 280z GT30/76R 441hp/381tq [email protected]
Z U L8R is offline   Reply With Quote
Old 01-28-2010, 10:37 AM   #7
240ez
240ez's Avatar
Na it wasnt an automatic before. I take it off and get it tested.
Old 01-28-2010, 03:43 PM   #8
240ez
240ez's Avatar
RB
I took off the starter, its good. The battery is good. when i put the starter back on. I connected the battery and the starter started to spin freely w/out engaging.
I knew i wired it backwards. So i disconnected the battery, re-wired the starter, and connected the battery. I turn the ignition and the starter makes a clicking sound but no crank.
Old 01-28-2010, 07:04 PM   #9
JRwerks
JRwerks's Avatar
Trader Rating: (55)
JRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of lightJRwerks is a glorious beacon of light
Feedback Score: 55 reviews
hmmm mine does same thing iono if it can bad igniton? put i just keep doing it until starter starts the car which is like 7times but it only does it sometimes wierd,.
JRwerks is offline   Reply With Quote
Old 01-28-2010, 07:11 PM   #10
Couped_up'd
Couped_up'd's Avatar
Trader Rating: (47)
Couped_up'd is an unknown quantity at this point
Feedback Score: 47 reviews
Try hitting the side of the starter (hit the solenoid part) as you start it...
Couped_up'd is offline   Reply With Quote
Old 01-29-2010, 01:29 AM   #11
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
it seems like the starter has lived its life and is dead now , cant push anymore weight.
take your starter off , go to a shop that specializes in startes in your city and compare it with a Nissan Forklift starter ... i did that , perfect match, works perfect.vgive it a shot
1992 240sx (RB20. [email protected])
eklips3 is offline   Reply With Quote
