![]() Join Date: Feb 2002
![]() A1000-6 Injected Bypass Regulator, P/N 13109 For high horsepower EFI applications where -6 AN fuel lines are used for supply and return. The Aeromotive A1000-6 Injected Bypass Regulator was developed for high horsepower EFI applications. Compatible with the Aeromotive A1000 Fuel Pump, this regulator is a cousin to our widely-used A1000 Injected Bypass Regulator, delivering performance, long-life, and reliable operation. Features: Base pressure is adjustable from 30 to 70 PSI. Alcohol compatible. Provides two -6 AN ORB inlet ports and one -6 AN ORB return port. Fuel pressure rises on a 1:1 ratio with boost. 1/8" NPT gauge port. Beautifully finished with type II bright red and clear anodized coatings. Click here to order ===> http://www.enjukuracing.com/products...tor-13109.html
