Old 07-21-2011, 02:58 PM   #1
rijndenn
rijndenn is an unknown quantity at this point
Dutch 2JZ S14 swap project
Hi im Dennis from the netherlands, im sorry for my bad English but its not my first language.
I own a s14 from 1995, and i bought the car 7 years ago. The car had some changes in the couple of years see the pics below
in holland we can order a mcburnout.
I had some fun these years with racing and drifting, but i got some problems with the sr20 (at that time +-320bhp)
I bought a lexus gs300 with a 2jz swap and fell in love with the 3L twin turbo. so much power an torque.
So i was making some plans with Niels en Rick (they build also the car of joes)
(see his topic #/f/chat/345784-niss...-widebody.html)
and make a new fresh build car from the bottom up. With a serious safty cage and custom made wheel tubs, so we can make a backwards entree in drifting
rijndenn is offline   Reply With Quote
Old 07-21-2011, 03:19 PM   #2
rijndenn
So i bought a 2jz-gte with a getrag v160 gearbox, the engine is a japspec engine complete stock with upgraded clutch. Got also a Holset hx40 turbo that is running at 1.5 bar a +- 700hp on a 2jz, but for troubleshooting we choose the stock twins first
A front sump is needed to clear the front crossmember.
so let the project begin... stripping.... sr20det out bye bye bye
alot of parts on the ground... it's must all be emty for the cage.
a very nice part comming in. the engine mounts for the 2jz
lets test fit the engine mounts
suceeded! porn!
Now its time to go the builder of the safty cage.
sketch of the cage.
Old 07-21-2011, 03:28 PM   #3
rijndenn
now their making the wheel tubs for more steering angle, the car is standing on all the driftworks handling parst. Inclusive the hub knuckels.
cut it
new oem steel
nice work!
Old 07-22-2011, 04:41 AM   #4
rijndenn
today we make the other side....
Old 07-22-2011, 04:51 AM   #5
bb4_96
bb4_96 is an unknown quantity at this point
Well done sir. Is that an S15 sr you pulled?
bb4_96 is offline   Reply With Quote
Old 07-22-2011, 07:26 AM   #6
turbo2nr
turbo2nr's Avatar
nice build so far
s14 kouki ka-t
Old 07-22-2011, 10:03 AM   #7
RB180sxChris
RB180sxChris's Avatar
RB180sxChris is an unknown quantity at this point
Nice build soo far
RB180sxChris is offline   Reply With Quote
Old 07-22-2011, 06:22 PM   #8
pandaroo
pandaroo's Avatar
pandaroo is an unknown quantity at this point
lookin good! im interested how the hx40 will perform on the 2j as im thinking about slapping one on mine myself. any idea were it would spool at?
89 2tone coupe
2jzgte swap in progress
pandaroo is offline   Reply With Quote
Old 07-22-2011, 07:00 PM   #9
jontron5000
jontron5000 is an unknown quantity at this point
Whoa, I've never seen a 240sx with that color red. Anyone know what its called or the color code?
Keep up the good work!
jontron5000 is offline   Reply With Quote
Old 07-22-2011, 07:13 PM   #10
cured13
cured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura aboutcured13 has a spectacular aura about
love Dutch projects
cured13 is offline   Reply With Quote
Old 07-23-2011, 06:43 PM   #11
blingbling
blingbling's Avatar
blingbling is an unknown quantity at this point
^right? The ones I see are always of the best quality
blingbling is offline   Reply With Quote
Old 07-23-2011, 06:52 PM   #12
miggypq21
miggypq21's Avatar
miggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud ofmiggypq21 has much to be proud of
Send a message via AIM to miggypq21
What kind of tow vehicle are you using?
So weird seeing a car tow a trailer and another car lol
miggypq21 is offline   Reply With Quote
Old 07-23-2011, 07:13 PM   #13
JOeS
JOeS's Avatar
JOeS is an unknown quantity at this point
It's a Citroën C5.
JOeS is offline   Reply With Quote
Old 07-23-2011, 07:29 PM   #14
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
great job so far!
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 07-23-2011, 08:58 PM   #15
acain
acain is an unknown quantity at this point
Looking good so far!!!
Not sure if you know but a tip i learned the hard was on my 2j swap!
If you use non turbo 2jz-ge oil filter housing and 2jz-ge water pump outlet pipe it cleans alot of the stuff up around the block that you dont need! Made my bay look alot cleaner!
Good luck with the swap!
acain is offline   Reply With Quote
Old 07-23-2011, 11:24 PM   #16
S14Driftr91
S14Driftr91's Avatar
Trader Rating: (26)
S14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to allS14Driftr91 is a name known to all
Feedback Score: 26 reviews
those tubs came out gorgeous !
www.allthingsproper.com
S14Driftr91 is offline   Reply With Quote
Old 07-25-2011, 03:09 AM   #17
rijndenn
thanks the credits of this project going to rick and niels.
that looks olmost JDM
Old 07-25-2011, 03:10 AM   #18
rijndenn
thanks for the tip! we keep that in mind.
Old 07-25-2011, 03:12 AM   #19
rijndenn
like Joed sad , a citroen C5 diesel, but it's that not common sight in your country?
over here we see it all the time....
Old 07-25-2011, 03:15 AM   #20
rijndenn
That one model looked really fierce! haha
the color called Rosso red, and the roof is subaru black.
all the body parts at this time is grey, but we paint it the same rosso color in red when its finisht.
Old 07-25-2011, 03:16 AM   #21
T chop
T chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enough
Have a thing called trucks and SUV's
And a lot of the trailers in North American are steel and heavy enough to carry equipment, most of the EU trailers I see in pictures are lightweight aluminum car trailers.
Here's an example when I had to deliver a 180 shell
T chop is offline   Reply With Quote
Old 07-25-2011, 03:18 AM   #22
rijndenn
ps thanks for posting the titays!
i have this turbo driven on a rb26 with a 2.8 stroker kit, and it spooled around 4500rpm....... so on a 3 liter i think like 4200its begins....?!
Old 07-25-2011, 03:24 AM   #23
rijndenn
mmm oke i see,
that kind of trucks are in the netherland really expensive in tax(i know its a shame), so you do'nt see them often. and over here you need a special drivers licente to drive with a trailer.
Old 07-25-2011, 03:33 AM   #24
T chop
Pulling a car with a car is cool, but I wouldn't be confident in the power or braking. In that truck I pulled my car (different car) with that trailer uphill doing 160 km/h without trying too hard. Pretty impressive considering it's a completely stock truck and an econobox car would have troubles doing that speed up the hill, obviously without pulling anything.
But anyway, back to your build, I will deff be following it.
Old 07-25-2011, 05:46 AM   #25
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
More pictures.
hahah looks sweet man!
HS13KLS is offline   Reply With Quote
Old 07-28-2011, 04:11 PM   #26
rijndenn
today the guys working 1.8 bar, credits i wish i could make that.
made a style dimpledais (spelled wrong i know)
cut off the rear fender
it needs more low!
some weight took off
wow that looks nice
test fit the chargespeed 50mm rear wide fender
Old 08-05-2011, 03:20 AM   #27
rijndenn
Old 08-05-2011, 03:48 AM   #28
DanielS14
DanielS14 is an unknown quantity at this point
could you post a couple more pics of that chargespeed over, they look good!!
DanielS14 is offline   Reply With Quote
Old 10-16-2012, 01:50 AM   #29
project_silvia
project_silvia is an unknown quantity at this point
Dope build bro keep it up
project_silvia is offline   Reply With Quote
Old 10-17-2012, 11:52 AM   #30
[email protected]
R@tch is an unknown quantity at this point
Shit is gonna be great, love the welding work and design of your tubs.
R@tch is offline   Reply With Quote
