Drift with water/methanol
Anyone have a water meth setup and drift with it? I was wondering if you would need a water surge tank so the pump doesnt cavitate from an air bubble. Curious as to what you guys think
![]() Join Date: Oct 2003
You shouldn't need a surge tank for a water/methanol, mainly because the liquid sees such high pressure after the pump. Just be mindfull of when your tank gets low.
#4 | |
Glad to see someone else who slides interested in taking advantage of what aux injection has to offer!
Just another broke ass drifter
![]() Join Date: Aug 2009
your pump shouldnt get air bubbles because the tank should be above the pump. I ran a 1gal tank with aquamist pump in my evo. I did mountain run in it just about every weekend with no problems. Aquamist HFS-1
Check Out My S13 Build |
You can get them up to 5 -7gal. anything above that will have to be special order. You can also make a tank.
I ran a 1gal in the evo, and that was plenty. Only triggers when you are above a certain boost level.
