08-23-2008, 05:22 PM | #1 |
Need help no power
well like the title says currently i have no power to the front driver side of my s13 hb
when i bought the car the lights were down and when turned on the lights came up but only the passenger side worked the wiring is all messed up in the car what i'm trying to do fix all the wiring and have my headlights and turn signals work please if anyone has incountered this problem let me know what you did so i can't get my s13 on the road |
08-31-2008, 07:02 PM | #3 |
all you can do is check all the wires make sure there are no shorts then check the fuses.. and replace what is needed.. good luck
www.massimopower.com PH: 1(951)402-5386 EM:[email protected] Special Thanks To: www.aeperformance.com www.domospeed.com/blog For Their Continued Support |
