Check list for 5 speed swap.
I am doing a swap on a s13. I have the following parts...
Mt transmission Mt crossmember Lower wiring harness Mt driveshaft Mt transmission bolts flywheel + clutch bolts Flywheel Clutch kit Pilot bearing Speed sensor Shifter Lower boot Master cylinder Slave cylinder Clutch lines Clutch pedal + assembly Fsm I plan to use the auto ecu and cut the brake pedal. The lists ive found I'm pretty sure I've gathered everything listed, was just wondering if I was missing anything else. Thanks |
#2 | |
Sent from my KYOCERA-C6745 using Tapatalk |
I'm pretty sure you only need one flywheel for this swap. But hey man, more is better so 2 couldn't hurt.
MRP Manufacturing |
#4 | |
![]() Join Date: Feb 2005
