newbie with a s14 zenki in FL
hey im new to the Nissan scene I have a 96 240sx with high miles, its leaking oil In the front by the crank area, idk what I have to change? anybody would input to change any parts like injectors? plugs? thanks in advance!!
![]() Join Date: Jun 2008
Chances will be better on getting some assistance if you take a picture of where the leak is coming from. It may just the front main seal. If the motor is high mileage, i'd recommend running a can of Seafoam through it, then change the plugs, wires, cap and rotor.
Easy there big guy... I remember when you came here asking silly questions.
My SR20VET |
I cant get any pics right now, its in the body shop, but the body guy took a look and says its above the crank so im guessing its the front main seal, also I wanted to do the rear 5 lug conversion but do I just need to buy the 5 lug hub? or more parts needs? thanks
ok, first i was giving you the benefit of the doubt, but seriously, Zilvia has a wealth of knowledge. Any question that you can ask, nissan related, has been asked before.
Spend a little time reading through the tech forums. Familiarize yourself with your car. There is no lack of answers on this site. Good luck!
