I teed of the FPR line to the boost controller and to the BOV line and another T to the Greddy boost solenoid. Now the car overboosts. Is it because i teed that line too many times. Can i get rid of that vacum line canister and block off the lines? Someone help!!!! I hit 8 pounds with my new front mount at 3K and am too scared to go higher in the RPMS.
Here is a pic and a diagram of what i meen.
Now i have an FMIC and that circle on the coldpipe plug is not there so i teed it of my BOV and it overboosts like crazy. 3K i hit 9lbs. Recoment smth, I wanna boost right al the way upto 7.5K even. What line should go to the Greddy Boost solenoid? I cant figure out how to pos pis so here it is on webshots. http://client.webshots.com/photo/308...15186823KJuhBT Some one plz help!!!! |
![]() Join Date: Dec 2002
I have no idea what that image is about.
its not clear enough for me. I would just run it like this. (only use the two nipples on the top of the trottle body) Take the small nipple and plug a line from there to the fpr, put the boost pressure sensor line in the middle. Take the big nipple and run a line across the front of the valve cover to a -T- that goes to the bov. Then take the other end of that t and run a line to the solinoid, then from the solinoid to the wastegate actuator. Try that. Make sure the controller is wired correctly. Thats all the vacume lines you should have. no canister, or anything. |
here is a better diagram
With the FMIC the yellow circle that nipple is not there!!!!! http://client.webshots.com/photo/308...15191877xltlDF |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
man next time use a program that you can type in
OK first remove the canister and cap off its line on the bottom of the TB next cap off any vac lines you have run that don't go out from the TB Then it is like blu said small line to FPR out T in it and run to boost gauge large line to BOV and Boost controler boost controler to wastegate on turbo now just follow the instructions and all will be well try not to over think the process
I never knew you could do that with an eggplant |
Thanx I am going to take off the t's and roune one line per item. One to BOV and one to Boost solenoid and keep the line to FPR and Boost gauge.
Hopefully it works. Thanx guys for all the help |
