![]() Join Date: Jun 2010
RB/240/Z32 Parts
No pics right now, parts are at the shop. ill get pics on tuesday, if you need them.
RB25 Intake manifold without TPS - Make Offer RB25 AC Compressor with Bracket and cut lines i can include the belt also - make offer RB25 OEM Water Pump (used unsure of condition) RB25 OEM oil pump (used unsure of condition) RB20/25 Exhaust manifold (x2)- make offer RB20 Turbo with lines, and compressor elbow, can also include the rubber intake tube thing if needed - TURBO SOLD. LINES AVAILABLE. S13 Brake master cylinder in working condition - Make offer Z32 Rear aluminum Uprights - SOLD Z32 Front spindles with upper control arms and hubs - Make offer Z32 struts, front and rear oem not blown - Make offer Z32 oem rear control arms (lower, upper, toe, traction) - Z32 REAR LOWER CONTROL ARMS SOLD 300zx 30mm Front rotors, oem, surface rust - Make offer Stock S13 Hatch Tail lights, Really clean, no cracks - Make offer Stock S13 Rear Bumper - Make offer S13 grey headliner for coupe with power sunroof - Make offer RB20 Braided Turbo lines for water feed and return, and oil feed. - $75 Update of Parts! RB25 A/C compressor with bracket, and cut lines. R33 Gts-T Main fuse box in engine bay with cut wiring. RB25 intake manifold with throttle body (no tps, no iacv, no hard lines under manifold, no injectors) will include new collector gasket if wanted Rb20 belts for water pump/alternator, and power steering oem rb25 water pump (used not sure for how long) oem rb25 oil pump (used not sure for how long) 2jz lower intake manifold, with stock injectors 2jz (n/a) distributor (has slight crack not sure if thatll effect it) Rb20 (possibly works on 25/26) transmission dust plate thing Treadstone vacuum block More stuff again! LS1 Stock intake manifold. no injectors. Ford 7.3l power stroke water pump. New. S2K Carbon Fiber lip. Broken but fixable. 2 j30 ignitor chips with pigtails. Bmw 5x120 1" spacers with all studs. (no lug nuts but its a 12x1.5 pattern) Mishimoto KA/RB radiator with small hole, fixable. Make offers on anything you need!!! i just need it all gone! trying to finish my car so trades are welcome but limited i cannot stress how open i am to the words OR BEST OFFER! if you want it, and you have a limited amount of cash... make an offer! i need this stuff gone and i want my car running! 99% chance i will not refuse a serious offer. Trades ill be interested in: 4 Lug Hubcentric 4x114.3 spacers (at least 25mm. Need 4 of them but will take em by the pairs) RB20/25/26 Timing belt (new not used) RB25 OEM new oil pump RB25 New N1 Water pump Water Temp Gauge with sensor (new in box would be awesome) Boost Gauge Oil pressure gauge with sensor (would be awesome to match the water temp and boost) Megan/Circuit sports Outer Tie Rods Power Steering Cooler Kit Oil Filter Relocation/Cooler Kit for RB25 New in box RB25 Nismo thermostat 550cc Sidefeed Injectors for rb25 S13 Hatch Over Fenders Silvia Headlight Wiring Silvia Hood AEM Wideband Some 17x9 4 Lug wheels (dont care what kind or condition or color as long as not bent) S13 Hatch Rear Aero 5 Point Harness RFL Bov Prob the wierdest request, I need a Receipt for a Mishimoto Radiator for an RB or KA, so i can get my Radiator warrantied out. Ill add to the list as i get more stuff to sell or want more stuff. also if you have stuff that i need, but i have nothing you want, pm me. well work out a price. Last edited by s13_rb25; 05-03-2012 at 03:38 PM.. Reason: Added more! |
id like to know a price on the ac compressor if you wanna pm it to me, i dont even know what to offer for it but id like to have the extra one just in case...
