#691 |
![]() Join Date: Jan 2007
Just thought I would share
- Oem rebuild - Brian Crower Cams/valves/retainers etc - Holset HE351 - Lightweight pulleys - Driftmotion Lightweight flywheel w/flywheel bolt lock
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#693 |
![]() Join Date: Apr 2003
Trader Rating: (33)
Sorry I was a bit vague. Im actually sticking with the R154 which is rebuilt using MC parts. Looking for about 500-600 lbs/tq when all is said and done. Looking to daily drive the car and take it to the track a few times a yr.
Dallas whats up bud. Wow the build is coming along strong. If I had the extra cash I would love to do a V160 and that clutch will be good no matter what you throw at it. |
#694 |
Can anyone offer some assistance with the Dakota Digital Wiring Boxes on a 1J S13? (Zenki, so Single Cam Tach)
Thus far, I've tried both output one and output two on the tach, and various combinations of the first and second dipswitch and gotten nothing. The Engine Cylinder count has been set correctly. Interestingly enough, my speedo is a bit jumpy at idle (perhaps 0-5mph jumps, maximum).... What are the odds that the inputs and or outputs on my harness are swapped - or is the speedo just jumpy without calibration? Thanks guys. |
#695 |
![]() Join Date: Sep 2010
So i wired up my 2j into my s13 yesterday, cranks but no start. i didn't have help so i couldn't check for fuel/fire. So does anyone know if the f1 starter trigger wire needs to be hooked up? Cause i know on a Sr or ka you have to have the trigger wire hooked up for the inj to fire in a certain order on start up.
#696 |
Well got back at it today and had a little help. Car is gettin fuel, but no fire
so that would make me think the efi relay is good since the inj and coils run off of it. Does anyone know how to check the ignitor? I googled it but only came up with diagrams or people saying just swap it. |
#699 |
I didn't extend all the wires just the ones that needed power and my grounds. But my s13 is just my drift car so I just mounted the ecu up against the firewall, on the inside of course. If you wanted to mount it in the stock location you would have to extend every wire, and that...... would take forever.
#701 |
Yep lol i only had 1 hooked up. Now the only prob Im having is when I turn the key off the car stays running, brake light on the cluster stays on. But it does it even if I disconnect the power to the ecu, ( the car won't run obviously, but the brake light on the cluster stays on) So I think its a ground issue, cause it never did it before with my Sr. Now I don't have the alt hooked up yet but i don't think that has anything to do with the issue.
#702 | |
![]() Join Date: Aug 2008
#704 |
It's not with the wiring because I disconnect the power to the ecu and it still does it. I think its a ground issue. None the less though, the motor sounds great and has awesome oil pressure lol
#706 |
finally got some traction, and it is nice not to worry about breaking loose into a drift all the time
93 s13 coupe 5 speed- Ls2 swap in the works 97 sc300-gte/v160 |
#707 |
Ok so i figures out the brake light issue and the car staying running, but this is very strange. All I did was take the ign wire from the ecu and grounded it. Now another weird thing is the fuel pump comes on when i do this as well. Isnt the ign switch supposed to be a 12v?
#708 | |
#709 |
Pin 1. The ign switch wire. But I'm gonna try somethin different cause the aem pin out even says its a 12v input. So I'm thinkin I'm using a 12v from a relay under the hood and its not grounding, so when i ground the ign switch it completes the circuit for the relay under the hood. I'm pretty sure I know how to fix it though.
#711 |
![]() Join Date: Oct 2007
Trader Rating: (53)
Hey guys, i plan on swapping a 1J into my car and i was wondering if you guys do anything in the front of the car to compensate for the extra weight of the motor? Right now i am running D-Max coilovers with an 8kg spring rate up front and i was wondering if that is going to be enough? Or will i have to buy new coilovers with a 10kg or 12kg spring rate?
#712 |
Trader Rating: (33)
Depends on what you plan to do with the car...daily, drift, drag, auto-cross. FYI, I plan to daily and 1/4 mile here and there and I am using FA 11kg front and 7kg rear as recommended by the techs at FA. I have an S14 with a 2j if it helps clear things up.
#714 |
![]() Join Date: Sep 2009
![]() Feedback Score: 22 reviews
You should up your spring rate. I'd go with 12k up front and 10k in the rear (I'm assuming you're running the standard 8k/6k), but it's generally not advised to go more than 2 kg up or down from your current spring rates without getting your coilovers revalved. So you don't need new coilovers, but it wouldn't hurt to look into stiffer springs (like at least 10k/8k, which you could safely get away with).
#715 |
![]() Join Date: Jan 2008
Most recent completed 2JZ swap at Zerolift
We produce a mount kit and driveshaft for this conversion. 1JZGTE / 2JZGTE into Nissan S13, 14, 15 chassis. Stock Front Subframe, S Chassis Motor Mount Compatible. No Cutting the Core Support Required ! We will have race motor mounts released very soon also !
Contact: Phone - 513-874-2508 AIM - ZLR0bert Email - [email protected] Zerolift facebook - http://www.facebook.com/Zerolift Last edited by Zerolift Autolab; 10-02-2012 at 10:02 AM.. |
#716 | |
#/f/tech-talk/449651...-write-up.html
#717 | |
#718 | |
Trader Rating: (53)
