![]() Join Date: Feb 2009
Trader Rating: (47)
![]() Feedback Score: 47 reviews
LOTS OF PARTS! s14| s13| boost controller|Something for everyone!
Very large for sale thread. Most this stuff is just laying around my house, tired of it being in my way all the time. THERE FOR everything is OBO!
S14 power steering resivor $10.00 S13 240sx fuel pump $10.00 Silver fitting (if there is away to tell size, pm me) $7.00 ka24de valve cover gasket $4.00 sr20det bottom mount turbo coolent feed line (fitting on the end of line is striped) $20.00 s13 240sx 89-93 Tein lowering springs, with badass shocks agy or somthing like that. $200.00 Random couplers, you have to by all. $10.00 5 lug 10mm spacers $12.00 ka24de clutch with good life, comes with 2x clutch disks. $20.00 Sr20det, was told it was a nismo. Good life on it. Unsprung. $55.00 g70 maf, s14, works, pulled to do a rb25 swap. $35.00 Rb20det left side only, valve cover. $15.00 JDM clitmate control box, comes with harness $45.00 USDM front s13 side markers, really good condition. $10.00 Left Chuki front bumper extention, used, and primered. $SOLD S13 fuse panels. I got 2x of them. 1x s14 $7.00 S13 left side mirror, looks to be a power mirror. $15.00 S13 tumbler. Works. $20.00 t3 to t3 adapter flange for a 38mm wastegate. $20.00 Left over ic pipes. Sale as a package only $15.00 S14 ecu. 1998, 5 speed $45.00 ka24de termal intake gasket. Never been used. $SOLD s13 front brakes, with brakets. $20.00 2x ka24de coils. Selling them as a package. $20.00 AN fittings for my aeromotive FPR. They fit into a aeromotive FPR. Used to go from an to soft line. $10.00 EACH Rb25det coil pack harness series 2? $25.00 APEXI AVCR Used, and in GREAT SHAPE! Works perfect. $275.00 ka24de starter, works. $15.00 OEM sr20det intake tube. $10.00 s13.4 overfenders convertion fenders, need work. Good for a body guy to fix? $60.00 ka ecu. $SOLD Rb20/maxima n60 maf. No pigtail. $35.00 sr20det manifold. No leaks. $20.00 Rb25det/rb20det smic set up. used on my rb25det. I think you will have to cut one pipe. Comes with smic, and pipes. $40.00 Painted, blue blackish ka24de valve cover. Had a local body shop paint it. $40.00 Last edited by Couped_up'd; 12-21-2010 at 12:50 PM.. |
Trader Rating: (47)
Sr20det redtop valve cover/ka24 valve cover
$sr30.00 $ka15.00 BADASS FUEL SET UP! Used on my rb25det! $300.00 SB FEED LINE, with in line filter & SB RETURN LINE This setup used a aeromotive FPR (not included) Good for A LOT OF HP! 2x walbro fuel pumps, already wired, and TIG welded alu. braket.Of course has the an fittings for the fuel lines. s13 240sx radio brakets $SOLD Rb20det coil pack cover $15.00 ES steering rack bushings. Tension rod bushings, front sway bar bushings $20.00 each S13 aftermarket sexy low seat. $SOLD Last edited by Couped_up'd; 12-21-2010 at 12:48 PM.. |
Sir
Pleas PM me with the diameter size (2.0", 2.5" or 3.0") and a total price for the pipeing shipped to 70458. I will also need your paypal info. This Thanks pallnet
SPEED IS MY DRUG OF CHOICE..LET ME DRIVE. |
