#4 | |
![]() Join Date: Jun 2006
God damnit I just bought a ecv argh!
![]() Join Date: Feb 2007
u pmed once dick and i responded in 12 minutes, had problems shipping with the address u gave me, not to mention my fckn phone number is on this page wtf smart guy
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
^ Wow seriously?
PMed right after I made payment-no response. PMed earlier-thats when I got your response. All you had to do was let me know before what the status was; you acknowledge in your post #6 that it was sold but I didnt hear nothing until today. My time is opposite yours so calling is not that easy. I figured if I posted in your thread, you would get back to me...I was right.
Clutch sold
EVC sold valve cover sold Make offers on the rest of the stuff, i am very shocked that nobody has grabbed the fcon, its a fckn HKS ECU and is almost identical to the gold version already tuned for sr FCK lol |
#17 |
I read the article. The author is incorrect. That unit is the FCON V look at the faceplate, it says FCON V NOT FCon VPro. Look at the title of the link that you posted lol
You want me to verify this with Jon Kuroyama who was the manager of R&D at HKS USA before they closed? I have the VPro and he tuned it. If anyone knows, he would. YOU need to learn wtf you are talking about before shooting off information which is incorrect. Last edited by usdm180sx; 01-12-2012 at 05:49 PM.. |
#20 |
If shitting on ppls threads is your thing then be my guest. Your de-valuing something im selling at an extremely good price and your scaring ppl away from buying it. It is essentially the same exact thing as the gold ecu I have both and they both do the same exact things. Everyone I know calls it the vpro including Aki Fuchigami, Naoto Negishi, Tadatoshi Waketa. So wtf if i added the word pro from what I was told and I dont give a shit what the jobless Jon Kuroyama has to say.
#21 |
The reason I checked out your thread is because I'm looking for another VPro. When I saw what you were selling I was like WTF? It's called the FCon V. End of story. How is clarifying incorrect info shitting on your thread? Where in this thread did I say anything bad about the FCon V? All I said is that it's not a VPro. And if you bothered to read about the VPro (On the same website that you posted BTW) you would have seen that they are indeed different:
FCon V (Silver box, the author calls it a VPro by mistake): The F-CON V Pro Silver series of HKS ECUs is the predecessor to the GOLD model. It features: • 24x16 INJECTION full-control map. • 24x16 IGNITION full-control map, for both main and sub ignition. • 24x16 INJECTION trim map. • 24x16 INJECTION correction map based on throttle and RPM. • 24x8 INJECTION correction map based on individual cylinder and RPM. • 24x8 INJECTION correction map based on throttle change and RPM. • 24x16 AFR target map for self-correction, applied to the 24x16 fuel trim map. • 24x16 IGNITION correction map. • 24x8 IGNITION correction map based on individual cylinder and RPM. • 24x8 IGNITION correction map based on throttle change and RPM. It also features 2 optional voltage outputs and 1 optional frequency output, suitable for: • Airflow-based trigger or output. • Pressure-based trigger or output. • Throttle-based trigger or output. FCON VPro (Gold box): The F-CON V Pro GOLD series of HKS ECUs is the top of the range designed by HKS. For fuel control, up to 8 injectors can be controlled, allowing for 8 cylinders sequential or 4 cylinder twin injector control. For ignition control, up to 6 independent lines can be controlled. Feature • 32x32 INJECTION map. • 32x32 IGNITION map. • 32x32 AFR target map. • 4 16x16 INJECTION sub maps, suitable for different fuel octane ratings. • 4 16x16 IGNITION sub maps, suitable for different fuel octane ratings. • 16x32 INJECTION and IGNITION correction maps based on speed and load. • 32x16 INJECTION and IGNITION correction maps based on throttle and RPM. • 32x8 INJECTION and IGNITION correction map based on individual cylinder and RPM. • 16x8 INJECTION and IGNITION correction map based on throttle change and RPM. • 16x32 IGNITION correction map based on air temperature and load. HKS F-CON V Pro GOLD It also features 4 optional voltage outputs and 2 optional frequency outputs, suitable for: • Replicating airflow voltage or frequency (piggyback-mode) • Airflow-based trigger. • Pressure-based trigger. • Throttle-based trigger. • Speed-based trigger. It also features input switches to trigger scramble mode of various types. Three (3) types can be selected at once, resulting in 8 different combinations. For non-software-based ignition and injection tuning, GCC (graphical control computer) is also available. This is connected to the specific 6-pin (3 by 2) connector, specific to either fuel or ignition. It allows for +/- 16 degree in steps of 2 correction, aswell as +/- X % in steps of 2 ignition correction. There are a TON of differences between these 2 units. For one, the VPro has 32x32 bit maps and the V only has 24x16 bit maps. Way to go to bash Jon. Just because he's jobless right now doesn't mean he doesn't know his shit. He still has clients that he takes care of but his personal life isn't the issue here. It's the same argument where people call a kouki 180sx bumper a "type x" bumper. They are not the same thing. Anyway, glws even though you're acting like a douchebag. And thanks for wasting my time and misleading ME into thinking you were actually selling an FCON VPro. Last edited by usdm180sx; 01-12-2012 at 05:52 PM.. |
