![]() Join Date: Feb 2002
Enjuku Racing - NEW PRODUCT - FiveO 550 & 750cc Injectors - $299.99
We have just started carrying a brand new line of Injectors. They are similar to Deatchwerks, but a TON less expensive.
550cc - ON SALE $299.99 750cc - ON SALE $299.99 550cc Injectors (set of 4) high performance Japanese Electronics Corp (JECS) fuel injectors - Custom Milled to flow 550cc. Each set is sold with a complete flow-data chart indicating individual dymanic and static flow rates at 3, 3.5, and 4 BAR at 25%, 50% and 100% for each injector, along with dead time (latency) period at 14 volts.. To insure a quality product our shop adheres to the highest standard milling and flow-matching using the industry's latest technology.. You receive the highest quality fuel injectors for superstreet and racing applications. As part of our quality control, each injector has been marked/inscribbed by our technician with an individual control number and is part of a unique flow-matched set. This injector set is for modified engines with high horsepower. See Chart below. This injector will fit Nissan SR20DET, KA24DE Injector Body Design: Metal and composite plastic Flow rates: (These are true and tested flow rates of this fuel injector. We use Heptane as our testing agent). 550-560 cc/min at 43.5 psi (3 bar) 590-600 cc/min at 50 psi (3.5 bar) 640-650 cc/min at 58psi (4 bar) All sets are shipped with a flow-data information document. Flow rates will vary slightly from set-to-set. Excellent low pulse width with predictable response. Excellent atomization for modern single and multi-valve engines. This set will require no more than a 1% trim for easy tuning. SPECIAL NOTE: All orings are supplied for installation. These Injectors are used and approved by RS Enthalpy Tuning. Great Inexpensive alternative.
Yes, we can get 550cc RB20 injetors. Email me [email protected] and i can get you a price.
thanks Ken
![]() Join Date: Apr 2008
Trader Rating: (161)
![]() Feedback Score: 161 reviews
Wow nice prices, I hope they stay like that when I'm ready to get a full set of the 750s for my new build!!!
180SXオタクだ! |
This is an introductory price, but the normal price isnt much higher.
Here are the specs on the 750cc's
FiveO - 750cc Injectors (set of 4) - custom milled from JECS original equipment blanks. To insure a quality product our shop adheres to the highest standard of manufacturing and flow-matching using the industry's best-quality equipment. Each set is sold with a complete flow-data chart indicating individual dymanic and static flow rates at 3, 3.5, and 4 BAR at 25%, 50% and 100% for each injector, along with dead time (latency) period at 14 volts. This injector set is for modified engines with high horsepower. See Chart below. This injector will fit all 1991-99 SR20DET, and KA24 - 4 cylinder engines and 1993-96 300ZX non-turbo. Injector Body Design: Metal and composite plastic Resistance: 12.5 OHMS, saturated Flow rates: (These are true and tested flow rates of this set of fuel injectors. We use Heptane as our testing agent). We provide flow sheets for each set. 750cc/min at 43.5 psi (3 bar) These JECS injectors are to within 1%. Excellent low pulse width response with predictable response down to 2ms. Excellent atomization for modern single and multi-valve engines. This set will require no more than a 1% trim for easy tuning. All have been remanufactured from original equipment Nissan fuel injectors to the higher flow rating and placed in flow-matched sets and are sold with our 3 Year New Parts Warranty.
#13 | |
Ken
We will get with them and get you the correct flow chart. For some reason 2 of the boxes didnt have them.
thanks Ken
#17 |
![]() Join Date: Dec 2008
I was wondering what a set of 6 550cc injectors would be for an RB25, shipped to 87107 (business address).
thank-you! Stephen P.S. - I sent a PM, but didn't get a response |
I've tried to contact Five-O directly for the past 6 months on getting some custom stuff done with no luck.
I hope you guys can whip them into shape, and keep these injectors going out your door. I went through 2 sets of Deatschwerk 740's with lots of coil issues in my day. This is a much better alternative. Good results to be had with Five-O's products. I'm glad we can deal with you guys at Enjuku directly about these. |
#19 |
We are working negotiations on RB injectors. I should know something soon.
They have been really good to work with so far and we are keeping them on our shelves. We have a bunch of the SR 550 and 750 on the shelf and plan to keep them well stocked.
#20 | |
extremely excited to order a set of these |
#21 |
It looks like RB20 injectors will be priced in the mid to low 4's for a full set and RB25's will run in the mid to high 4's.
They should be posted on the site within the next few days and on the shelf. thanks Ken
#22 |
any idea if you will be running a sale on the RB series injectors like you are on the SR? and if you guys do plan on it, and idea on how soon?
Pretty happy to have another choice of injectors (which from research I haven't heard anything negative about...) |
#23 |
RB Injectors have been added to the site
Enjuku Racing - Performance Parts and High Quality Fabrication RB20 and RB25 available in 550 and 750 thanks Ken
#25 | |
thanks Ken
#27 |
All injector sets are sold with the manufacturer's warranty plus a 36 Months/Unlimited Miles Warranty
#28 |
Only a few sets left at the intro price and then they are going up, for good.
ORDER ASAP Ken
