Old 01-10-2010, 08:33 PM   #1
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
s13 intercooler piping
alright , i know intercooler piping is a sinch to install and i've done it countless times.
but im trying to figure out what kit to use with my scenario. buddy of mine is doing a S14 SR swap into his s13.
so my dilemma is... what intercooler kit to buy ? do you have to mix and match with a s13 and s14 kit ? or will a s14 kit work ? or maybe even ca18 kit ?
thanks guys
1992 240sx (RB20. [email protected])
eklips3 is offline   Reply With Quote
Old 01-10-2010, 08:38 PM   #2
HPballer76
HPballer76's Avatar
HPballer76 is an unknown quantity at this point
s14 kit. takes a couple of mods though..
HPballer76 is offline   Reply With Quote
Old 01-10-2010, 08:39 PM   #3
eklips3
eklips3's Avatar
sweet! thanks
im guessing the mods are cutting a hole in the battery tray.
anything besides that ?
Old 01-10-2010, 08:45 PM   #4
Jonnie Fraz
Jonnie Fraz's Avatar
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Send a message via AIM to Jonnie Fraz
No...some of the piping needs to be cut and welded. On the one I did we used both an S13 and S14 piping kit and had to cut re-clock a couple of parts.
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 01-10-2010, 08:58 PM   #5
eklips3
eklips3's Avatar
could you explain in detail on whats to be done in terms of which pipe and where to cut ?
and im assuming you use s13 hotside with s14 coldside, correct ?
Old 01-10-2010, 11:57 PM   #6
HPballer76
HPballer76's Avatar
all i did was take 3 inches out of the hot pipe so that the hood would close. everything else fit. check out my build thread there is more info and pics on this entire swap in there.
heres the link
#/f/chat/282746-hpba...-s14-sr20.html
Old 01-11-2010, 03:40 AM   #7
eklips3
eklips3's Avatar
sweet thanks alot man. build thread helps me alot.
i just dont understand how yoou said that you took out 3 inches from the straight section on the hotpipe .. i dont see any welds , plus how would shortening the straight section let you have more hood clearance ... it would only shorten the pipe.
can you clarify that for me ?
Old 01-11-2010, 09:37 AM   #8
HPballer76
HPballer76's Avatar
i took 3 inches out from where the pipe turns down to go through the body. therefore lowering the pipe enough for the hood to clear. if you look at the pics in there you should be able to tell. or when you get the intercooler and pipes in your car you will see where it needs to be cut.
Old 01-11-2010, 09:43 AM   #9
HPballer76
HPballer76's Avatar
here is a pic. i took 3 inches out of the vertical section
before.
and after
hope that helps. let me know if you have anymore questions about the swap.
Old 01-11-2010, 05:27 PM   #10
eklips3
eklips3's Avatar
wicked , you were a great help man ... stay ballin
Old 01-11-2010, 05:39 PM   #11
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
Or you could get a powered by max kit and not have to worry about cutting and welding the piping back together.
But your piping should be for the motor, not the chassis.
LayNLow is offline   Reply With Quote
Old 01-11-2010, 05:40 PM   #12
HPballer76
HPballer76's Avatar
no problem dude. like i said if you need anymore help just let me know. my swap has been in my car and running for about a year now so ill do what i can to help out.
