Old 02-20-2013, 06:30 PM   #1
240sxMac
240sxMac is an unknown quantity at this point
Car won't start
My car won't start, it started and ran then died on me, then I tried to start it again, won't turn over. my lights and everything turn on so I don't think it's the alternator. My battery I checked like 2 weeks ago. it was good.
so battery is good.
I thought it might be the starter, I just so happened to have an extra laying around from a swap, so I tried that. nothing.
I think my ingition switch may be bad, my buddy said I may have snapped my timing chain. but I'm not sure, even then I'd think it try and turn over, or at least make some noise when tryin to turn over.
help me out peeps! I need my car.
240sxMac is offline   Reply With Quote
Old 02-20-2013, 06:32 PM   #2
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
does it crank at all? or u just turn the switch and nothing happens?
Juantwo3 is offline   Reply With Quote
Old 02-20-2013, 06:42 PM   #3
LB 180SX
LB 180SX's Avatar
Trader Rating: (18)
LB 180SX is an unknown quantity at this point
Feedback Score: 18 reviews
does it stay on if you turn the ignition and hold it? (dont leave it for too long though)
LB 180SX is offline   Reply With Quote
Old 02-20-2013, 07:59 PM   #4
240sxMac
I can't get it to start again, won't turn over at all.
just make one click when I turn the key to start it. then nothing.
Old 02-20-2013, 09:43 PM   #5
LB 180SX
LB 180SX's Avatar
Trader Rating: (18)
hmm. check starter cables. power and ground. ground is known to come loose
Old 02-25-2013, 11:01 PM   #6
Ryanswartout
Ryanswartout's Avatar
Ryanswartout is an unknown quantity at this point
your starter isnt grounding if all you hear is a click your solenoid is poping, easiest way to fix this is to get a 6$ ground cable (2 gauge wire) from oreilys bolt it to you intake manifold and connect the other end to your battery your car will start =D
Ryanswartout is offline   Reply With Quote
Old 02-27-2013, 08:44 PM   #7
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
If you are having problems with your car starting check out this old post I responded to years ago.....
#/f/tech-talk/56158-...ggestions.html
Hopefully the information in it will help you solve your problem.
Here's what the ignition switch looks like
http://www.autopartsnetwork.com/shop...Fch7QgodoG8A2Q
Good luck!!!
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 02-28-2013, 01:26 PM   #8
240sxMac
Thanks for the info!
