Old 02-27-2017, 02:59 PM   #1
OnThatLoud87
OnThatLoud87 is an unknown quantity at this point
s13 Lots of help needed
Never posted on here before but I've been reading a long time, last October I picked up a 93 hatch with a Silvia front end from down in PA.
Wiring was pretty hacked up so I started by putting a wiring specialties harness in for the motor, a sr20det into s13 harness. I currently have the apexi power FC D jetro the car came with in it for an ECU. after swapping over the wiring specialties harness I noticed that for whatever reason the Body harness connector was the female side of a SOHC white plug and that the correct end was wired into the old harness. well, i manually pinned all those wires into my new harness trying both the white SOHC and brown DOHC plugs and neither made a difference I'm still not getting power to the ECU.......
Being that so much of this wiring was hacked already should I just do an entire chassis harness? the cars already gutted and caged so i wouldn't need to remove much to get to the little wiring that's in there, it's only a summer car so heat and air conditioning aren't important, neither is defrosters or anything like that. all the radio wiring has already been ripped out etc.
OnThatLoud87 is offline   Reply With Quote
