![]() Join Date: Aug 2015
noisy motor need knowledge
Let me borrow your ears for a second it's coming from the front is it timing chain slap ?
http://youtu.be/CqtJiU8f1NY |
It sounds worse after revving it up but here's the start up and rev
http://youtu.be/Rb6eflgYmGI http://youtu.be/ossf9DPQf3E |
A buddy of mine did the assembly and took it to a shop nearby for the machining . Fresh valve seals but valves were reused ..
said they looked good Bottom end is wiseco 87 9.0:1 Pistons Factory rods Clevite main and rod bearings |
It sounded fine the last 200 miles but I just replaced my cams (stock) because previous owner neglected oil and cams worn down a lot from oil squirters being clogged up
![]() Join Date: Jul 2005
Clevites and clogged oil squirters... the engine is trash.
Rebuilt sr20det rarely make the 1000 mile mark. Very important to keep them doctor clean when opening it up... clogged oil squirters is very common on engines rebuilt poorly due to lack of cleanliness and marks the end of the engine. You wipe a cam lobe and send metal through the engine its almost always gg. |
It was clogged before the rebuild and I ddnt realize the cams were worn till it was back in the car but that would clog up oil gallery's yeah? The entire duration of the cams were worn maybe half a mm
