Timing the distributor.?????
So im 95% done with my rebuild and im stuck. I set the motor at tdc lined up all the marks with the timing chain, everything was good turned fine with no noise, but how to set the dist? set it at tdc on the compression stroke on the #1 cylinder right? and set the dist. to fire on #1 right? and should it just fit right in? any tips?
