sr20 s14 arc side mount effiency?
Im about to drop in a s14 sr and im going the ARC side mount route and was wondering what kind of boost pressure it can handle? I hear a bunch a different numbers ranging 14 psi to 20psi. Any ideas?
I'd just make sure you run the ducting for the side mount, when I had the OEM side mount on my car, the ducting made a huge difference on the intercooler temp.
As long as you have air being properly routed to it, I'm sure you will be fine. |
