quick front end question..
I know with every alignment and adjustment in caster the answer to my question will change somewhat but here we go...
question=Will i need to tub my front end before up coming steering work changes ... the set up is on s13 fastback.. super hicas rack PBM max knuckle mod pbm tubular flca with tension pbm inner s14 touge factory s14 outer with 17x9 +12 could run spacers but no more than 15mm /225/45 tire 3.5camber / close to or alil north of factory on caster Do you think i will need tubs ? thinking ill be hitting the frame rail more than anything ! thank you thank you thank you .. |
right on ..
Seem to be rubbing the shit out of my fenders at the moment running stock knuckles... but your thinking the track will be adjusted out with the FLCAs so there will be no issues? |
![]() Join Date: May 2009
pull the fenders abit, add spacer so rim doesn't rub on coilover,
and if it rubs when you turn then hammer the inner area behind front tires if you really want to tub heres some info and advice! What are you guys using to tub the front of you car? - Hardtuned.net - Page 2
☆*Nissan-RPS13☆Nissan 350Z*☆ ☆*Toyobaru FRS☆Toyota XB*☆ ☆*o(≧▽≦)o*☆ |
