![]() Join Date: Dec 2007
Search for the stretch and largest tire threads. they may give you a look at what it will look like and if they needed fender rolling or pulling.
For Sale threads: #/f/sale-items/33286...tons-pics.html Review Thread: #/f/private-sellers/...-chhheeee.htmlTRADER RATING: #/f/traderratings.html?u=66301 |
Thank you for your opinion on how they look...
My whole point for posting this thread was to obtain some information to read and thus educate myself. I ended up testing fitting them on someone else's 240sx. At a 1.5" drop they will rub the stock lower valance. With an air dam this is possibly/probably not an issue. At stock ride height I suspect minimal if any interference. I believe 225/50/16 to be a better tire size than 245/50/16 for these wheels on this car alas... that is not what is on the wheels... |
Admin Asshole
![]() Join Date: Mar 2002
S13
Roll and Pull with a baseball bat 18x9 +15mm front 225/40 18x10 +20mm rear 245/40 Car is fairly slammed on coilovers with no rubbing. You can find A LOT of information in the Wheel Fitment Whore Thread in Chat.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
take this as a rule of thumb.
for a stock body s13, get as close as you can to 17x9 +15 225/40/17. this is an ideal size if you don't want to pull fenders. figure out what that translates into 16's in your case.
![]() Join Date: Feb 2006
I agree with Bushido but i say more along the lines of 17x9 0 offset.
17x9 +15 is a bit sunk with the usual camber that comes from a good slam. Also, i dont know why some people are so scared to roll or pull. Once you do it youll see just how silly people sound when their stressing about it. ANd for the record. Heres my old 15x8 -10 on just a roll. With a 195/50. So a 215/225 with a 15 mm less offset will be fucking cake with just a roll.
IG: DARKSQUADNIGHTMARE DARK*SQUAD. SINCE 2005. |
Man w/ CTSV & a Car Seat
Okay, ideally the what your shooting for is the stock 205/55 16 diameter wise. 245/50 16 is oversized compared to that diameter, you'll need to get smaller tires if your having issues at full lock. If money to buy tires is an issue and youre just having slight issues with it rubbing on the valence, maybe you can adjust the caster/alignment of the wheel to move it away from the valence...
