Old 09-28-2010, 07:14 PM   #1
nevertheless
nevertheless's Avatar
nevertheless is an unknown quantity at this point
Sr20det wont start, wwwtttffff
alright i have a few questions, First off It was running a few days ago, went to the gas station and died. Pulled her home to do a few tests to check to see if my fuel pump is even working, and thats not getting power whatsoever. I hardwired the fuel pump relay to where I can get direct power from the key to the fuel pump. I tried to crank it but still no start, so I checked to see if I got spark and nothing shows. I check the clips going to the coils and the middle wire has power when I turn the key on. and on other hands I checked the fuel injectors clips when cranking the motor and nothing. Is there anything I can check to see if the ECU is bad and the Ignitor chip. also what is this dial thingy on the ECU?
I need your helpz! PS wtf
nevertheless is offline   Reply With Quote
Old 09-28-2010, 07:22 PM   #2
midnight_rex
midnight_rex is an unknown quantity at this point
that dial that you are looking at is the knob to put the ecu in "diagnose mode". when u turn it to the right (i think) it will throw codes if any. when you turn the key does the light on the ECU turn on at all?
here is a source to check the ecu:
ECU Fault Codes
also check all fuses and relays.
midnight_rex is offline   Reply With Quote
Old 09-28-2010, 07:27 PM   #3
nevertheless
As you can see here, the light turns on when the key is on the on position
This tool here is to check to see if the fuel injectors are getting power. When I crank the motor the light does not blink, therefore my injectors are not getting any power when cranking the motor.
Old 09-28-2010, 07:30 PM   #4
nevertheless
ECU Fault Codes
The light does not come on at all. We also checked all the fuses and relays multiple times.
Old 09-28-2010, 07:35 PM   #5
sidedrifts13
sidedrifts13's Avatar
sidedrifts13 is on the path to ruinsidedrifts13 is on the path to ruin
Send a message via AIM to sidedrifts13 Send a message via Yahoo to sidedrifts13
check all your grounds on the ecu and check your wiring and the ecu pin outs
sidedrifts13 is offline   Reply With Quote
Old 09-28-2010, 07:42 PM   #6
nevertheless
well i already have done so. an also added acouple new grounds. do you know witch pin's i should check?
Old 09-28-2010, 09:18 PM   #7
midnight_rex
is this in a s14 or s13? i know in the s14 there are 2 relays near the dash and ECU plugs. one is for the fuel pump and the other is for the ECU. check those relays. switch them out for good ones. seems like you have a ground issue or a relay just went bad.
Old 09-28-2010, 09:26 PM   #8
nevertheless
This is for an s13, Ill try that out.
Old 09-28-2010, 09:42 PM   #9
midnight_rex
my mistake, the fuel pump relay is located on the driver side footwell for the s14's. i dont know about the s13's tho. the other relays on the passenger side should be for the ECU.
Old 09-30-2010, 05:52 PM   #10
nevertheless
How do I check to see if power is coming out of my ECU? Problem is Im not getting fuel or spark. my fuel pump, maf, coilpacks, injectors arnt getting power.
I have tried to do it myself, on one pin the fuel pump kicks on, on another the relay kicks on, I used a light tester.
Old 09-30-2010, 07:12 PM   #11
nevertheless
Messed with the pins in the ecu, and everything started getting power, got it to start, we had to redo the timing, tried cranking it again, and nothing has power again!
Old 02-21-2011, 12:58 PM   #12
jvega
jvega is an unknown quantity at this point
i think i have this same problem with my s13 sr20det. Have you fixed it yet?
jvega is offline   Reply With Quote
Old 02-22-2011, 07:06 PM   #13
nevertheless
It was a bad ECU.
Jessefuckinwood
Street Prowl
Old 02-22-2011, 07:27 PM   #14
jvega
same here.. Just last night we tried my ecu on my friend's s13 and it didnt wanna start. It didnt turn the fuel pump on or anything!
We plugged his ecu back in, and it started right up.
Old 02-22-2011, 07:35 PM   #15
nevertheless
Funny thing is we took apart the bad ecu and found a bridge in the corner that popped, my friend saudered it for shits and giggles and we plugged it in and it started but the cluster lights stayed on after we took the key out haha
Jessefuckinwood
Street Prowl
