Old 02-24-2002, 07:40 PM   #1
40oz
40oz is an unknown quantity at this point
i'v been looking in to buying a 240 for a long time and im gunna do a swap but what is there to do to the stock engine for little money that would make more horse easy.
40oz is offline   Reply With Quote
Old 02-24-2002, 07:45 PM   #2
DSC
New Title
DSC is an unknown quantity at this point
define a little
DSC is offline   Reply With Quote
Old 02-24-2002, 07:56 PM   #3
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
nitrous will make more horse easy
whateverjames is offline   Reply With Quote
Old 02-24-2002, 07:58 PM   #4
40oz
im thinkin around $1000. or depending on if i can use the parts on the sr20det engine i would consider using more money.
(Edited by 40oz at 11<img src="#/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>3 pm on Feb. 24, 2002)
Old 02-24-2002, 08:12 PM   #5
DSC
New Title
How long have you had the car?
Come on a thousand! If your actually serious about doing the swap just put that thousand towards it and deal with a slow car for now...you will be soo much happier with an fmic for a grand on your new engine than a n02 system.
Or if you can't stand not modding your car, do what I'm doing, just build up the suspension (or stero or whatever you like cept for the engine) and don't touch the engine while you wait for the right time for the swap.
Old 02-24-2002, 08:20 PM   #6
40oz
ok thanks. what type of suspension is the best for the 93 240sx?
Old 02-24-2002, 08:34 PM   #7
DSC
New Title
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from 40oz on 8:20 pm on Feb. 24, 2002
ok thanks. what type of suspension is the best for the 93 240sx?</td></tr></table><span id='postcolor'>Thats a pretty broad question, I assume you meant springs/shocks? I dono what are the best for s13, I've heard kyb agx shocks w/eibach pro-kits are great. Or tokico (sp?) blues w/eibach pro-kits...I think they have those for s13's. Thats the most common first step. Another very common thing to do to upgrade suspension are sway bars and strut tower bars(stb's), although the stb's I don't think are the best bang for your buck as a first suspension mod. You can get the sways and stb's at <a href="http://www.pdm-racing.com" target='_blank'>http://www.pdm-racing.com</a> and other places, check the links section on this site.
For info on what these 3 things will do for your handleing check out THIS article. try Springs, Shocks, Anti-roll bars (aka sways), and Chassis braces (STB's)
Also haveing some nice tires should help just as much as the mods above, so don't neglect those...
