#31 |
![]() Join Date: Jul 2002
What truenocoupe is saying is that his starting point should be at the track, not the parts store. The only way to know what to improve is to first find out what is weakest by DRIVING the car. Seat time will lower your lap times more than any modification will when you first start out.
Allen Delta Region SCCA SM 1990 240SX SR20DET |
#32 | ||
![]() Quote:
Except maybe by only eating every other day for 2 months. j/k. Good info!I'm curious though - do you race competitively, and when (pre)teching, have any techs complained or pointed out your spacers? Cheers! |
#33 |
Junkie
![]() Join Date: May 2002
Wow...this really turned into a "are spacers safe" thread. Friggin hi-jackers.
On a side note...it's good to see people have had no problems with spacers on the track.
-Juan |
#34 | |
#35 | |
#36 | |
Rules of Boozing #10: Do not make eye contact with the bartender if you do not want a drink. |
#37 |
To some of us there is a difference between the casual enthusiast who might make an autocross every now and then and those of us that plan our lives around the events calendar for the year. Vacation with the family can only happen in this week in june because I don't have a race those two weekends. You understand what I'm saying. While there may not be a lot of talk in the motorsports section here, it's a lot better than some of the other sites. 240sx forums is full of "drift kings".
#40 | |
#41 | |
When you are really crazy about racing (or maybe just plain crazy) you get a tow vehicle like this: |
#42 | |
btw my kart handles better than all your cars combined ![]() |
#43 |
Junkie
Cars have four wheels....so do karts. Take that for nothing in common. The lack of suspension might be comparable to a very stiff suspension.
-Juan Last edited by 240Stilo; 03-23-2004 at 11:55 AM.. |
#44 | |
![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 8 reviews
think, if u run 7mm spacers how much thread will be left for the lug nut, what is the safe turn number? if i remember right alot of tracks require that the lug nut make so many turns befor its tight? but if u run stock studs with a spacer u risk poping lug nuts off if your spacer is thicker than i think 5mm??
![]() 1990 hatch ka24de gt2871r |
#45 |
I've found this website to be very useful. In it you'll notice that they make mention of widening track (both front and rear) to create a more oversteer-prone suspension setup.
One way for us S13 guys to widen our front track is to install S14 LCAs, which gives about 10mm more per side.
#46 |
lol damn, i just was about to toss soem s14 fornt lca's, i took the good ball joint out of one to keep as a back up. hmm, maybe i ll have to look into that after i get my new rims and wide fenders on....
oh i ran 225-40-17 on 17*7 last summer, and got rid of 2 of the tires, and had big brakes on the front so i ran the 17's on the fornt and se wheel on the back with cheap 195 wide tires, all it was good for was donuts and burn outs, cause when i tried to slide corners it would spin too easy and the fornt gripped to much, it always resulted in a donut cause of too poor of traction, and in general it handled like shit.but i got rid of the rims to get some wider lower offset ones.
#47 | |
#48 |
![]() Join Date: Sep 2003
I'm happy with my 225 45 17 fronts and my 245 45 17 rears. I have plenty of traction, this with my KYB AGX's, sport line springs, strut tower braces, tension rods, Tien tie rods with spacers, ST sway bars, and my power brace.
David Munoz, 1989 S13 KA24ET 1990 Infiniti Q45 To push oneself to the limit is all that one can do. To quit is to die. |
#50 |
Naw, but once my brother gets back from Mexico with my DigiCam I can take some for you. It looks really clean and it's smooth. I'm going to run 235 45 17 fronts and 245 45 17 rears next time around since I found that they fit perfectly fine.
#51 | |
I dont know much about how suspension works on cars, but I do know a bit about how karts turn. I drove a single seater once (obviously race prepped, w/ much stiffer suspension than your roadcars would ever rock), it was very different from a kart. Karts must lift the inside rear to turn, the reason the rear track is typically so much wider (it gets very close in rain setup) is because the kart relies on weight jacking to turn. If the front gets too wide it will cause to much weight jacking and the IR will lift too much and start to oscilate and cause the kart to 'hop'. |
#52 |
![]() Join Date: Jul 2003
Just to let everyone know, you can get nismo studs from http://www.performancenissanparts.co...roducts_id=161
for $54 and they're located in Socal. I'm picking up some later today. |
