1990 300zx drift ready
Selling my drift ready 1990 300zx. $6,500 OBO! Worst I can say is no.
This car was great to me this last year but looking for something else for me for next year. I drove this car to every event 2-3 hours away drifted it and drove it home, never failed me as I did about 10-13 events! Car has a swapped 94 vg30de engine and a 94 trans with around 75k on them. Body has almost 200k. Custom made roll cage put in when it was pro am drifted. The underbody is very solid! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() All listed below has less than 6k miles on them Dual pop chargers Inland one piece drive shaft Lightweight flywheel and pulleys New radiator New belts New plugs New valve cover gaskets New lower intake manifold gasket New upper intake manifold gasket New rear main seal new headers that are header wrapped Dual intake fuel filter relocation Fuel dampener delete Nismo fuel pressure regulator Z1 twin disc racing clutch Upgraded 350z clutch fork chromoly pivot ball New trans output shaft seal TYC dual electric fans New injector pigtails New coil pack pigtails Every connector on engine harness has been replaced Socketed and chipped ecu done by SZ runs on 93 octane New pro sport oil pressure water temp and volts gauge Walbro 255 fuel pump Kts coilovers and spl suspension parts, new tie rod ends Inline hydro brake S14 welded diff Top speed short throw shifter Z speed solid shifter mount Z1 solid aluminum engine and tranny mounts Oem timing kit Full deletes BDE bronze shifter bushings SS 1 piece clutch line All new silicone hoses and fuel lines Custom 2.5" exhaust to single n1 muffler Car will also come with a box of extra stuff and I have a great conditioned stock z32 TT wheels (which are worth more than NA wheels) Also have modded shortened knuckles made by Bryan that aren't installed but can throw them in with the sale. Just about everything on this car was replaced when swapped with a VG back into it. Obviously body isn't perfect but it's been on the track for about 10 years. Prefer cash/bank check or I will consider trade for another rwd car or a decent truck, would have a little cash to add on top if needed. Car was built by a very reputable z32 owner. Feel free to ask any questions also have a lot more pictures if you're a serious buyer. Thanks for looking. My number is 715-210-9144 My name is Jayleen If you have any other questions or want more pictures. Sent from my iPhone using Tapatalk Last edited by ZLady; 01-19-2017 at 01:32 PM.. |
