Cant remove EGR pipe from header
Trying to remove the header but I cant seem to get the EGR pipe disconnected from it. Ive tried using penetrating oil but I still cant get it off. Any tips?
![]() '91 Hatch - Work in Progress |
![]() Join Date: Sep 2007
deuceforty has the right idea and less work. extending the wrench works great!!! make sure to lube it up nice though. its a b**ch to get off though i went through the same thing to put my old hotshot headers on.
taking life a day at a time never looking back. |
Ive been using kroil which is supposedly good stuff and I just had a guy whos 6'3 220lbs (im like 5'9 138lbs) and he still couldnt get it... Not quite sure what you mean by extending the wrench.
![]() Join Date: Jan 2008
Location: Amerika24 alabama: Where if your not first..... your last
Lets see first off you fail for running an egr just block it off. Cut the tube and take the whole header off (its much easier) Then put a socket on their and zip it off with an impact. Ive had to do this many of times. If you still want to run an egr ill sell you a new tube+valve for $5.00 plus shipping just to help you out. ![]()
#8 | ||
![]() Join Date: Nov 2006
![]() Quote:
#9 | |
mslenghttttttttttt
![]() Join Date: Jul 2005
pipe wrench worked for me...you wont ever be able to put a box wrench on it again, but still, it grips on there like a mofo. if need be bust out the bfh and put thunder down on that wrench to get it going
I got mine off having hard time putting it back on....
shoudla just ran block off...anyone know what tubs need to be plugged after u block it off? also how to prevent the check engine light ffrom comming on making car run in default mode..
![]() Join Date: Dec 2004
Extended wrenches FTW! If you can't get it off, go lift some weights. I used to soak a small rag wtih WD40/PB and sit on there, then attack it.
If you wanna plug it, you should use a nickel. Fits perfectly and securely. |
#17 | |
#18 | |
![]() Join Date: Jan 2010
