Old 03-05-2014, 06:16 PM   #1
92R32GTST
92R32GTST's Avatar
92R32GTST is an unknown quantity at this point
Rb20 misfire!
Rb20 misfiring on back 3 cylinders with newer coil packs.. It's not the coil packs I already checked. Also revs veryyyy slow. Rich and pops, idle around 1k. Would rb25 maf cause this? (Green label). Thanks guys, I already searched btw and everyone else had slightly different probs.
92R32GTST is offline   Reply With Quote
Old 03-09-2014, 03:53 PM   #2
92R32GTST
92R32GTST's Avatar
Bump, Ignitor? Still misfire. Brand new coil pack harness
Old 03-10-2014, 03:22 AM   #3
s14-rb20det
s14-rb20det is an unknown quantity at this point
check your TPS, CAS and MAF
s14-rb20det is offline   Reply With Quote
Old 03-10-2014, 06:43 AM   #4
92R32GTST
92R32GTST's Avatar
Would a maf cause this it to idle and rev real sluggish?
Old 03-10-2014, 07:02 AM   #5
s14-rb20det
Yes, but my question is your car run find before? Do you check fuel pressure spark plug? RB25 and rb20 maf s1 is the Same. Check your intercooler pipes.
Old 03-10-2014, 07:04 AM   #6
92R32GTST
92R32GTST's Avatar
I don't think it's s1 maf though lol it's a green label. Kid wasn't brightest. At times it would wanna run ok but would break up like fuel cut up top and then would fall back into subie mode. A little free rev and she would run ok again till you jumped on it under a load.
Old 03-10-2014, 07:07 AM   #7
baube
baube is an unknown quantity at this point
injectors maybe?
back 3 are on a sub-harness...
baube is offline   Reply With Quote
Old 03-10-2014, 07:08 AM   #8
92R32GTST
92R32GTST's Avatar
Back 3 cylinders are missing. I just bought injectors already has a brand new harness so we'll see if this Ignitor and injectors wirk
Old 03-10-2014, 07:08 AM   #9
s14-rb20det
Originally Posted by baube View Post
injectors maybe?
Maybe you have A/F gauge?
Old 03-10-2014, 07:11 AM   #10
92R32GTST
92R32GTST's Avatar
Don't have a wideband hooked up
Old 03-10-2014, 07:16 AM   #11
s14-rb20det
So how do you know the car run rich?
Old 03-10-2014, 07:22 AM   #12
92R32GTST
92R32GTST's Avatar
Black plugs and stinks like gas
Old 03-10-2014, 07:31 AM   #13
s14-rb20det
Ok Before you going crazy, you going to have to start from the beginning, check your fuel pressure 42psi, reset You ecu, check your plugs, turbo pipes
Old 03-10-2014, 07:38 AM   #14
92R32GTST
92R32GTST's Avatar
Isn't there a certain way to reset the ecu? You can't disconnect battery? New to rb ecu's p
Old 03-10-2014, 07:49 AM   #15
s14-rb20det
Yep disconnect the battery and step on the brakes for 2 min, in my car do the trick.
Old 03-10-2014, 08:01 AM   #16
92R32GTST
92R32GTST's Avatar
Lol ok. I appreciate the information to guys that's awesome. When I get home I'll reset the ecu. Also I noticed the red led on ecu blinked 5 slow times followed by 5 fast blinks. Code (55) but that code came back to meaning it was running good? Lol
Old 03-10-2014, 08:07 AM   #17
Cronus577
Cronus577's Avatar
Cronus577 is an unknown quantity at this point
I'd pull the plugs and make sure they're gapped correctly. Or get rid of the RB20 completely, the thing is a boat anchor and worthless :\
Cronus577 is offline   Reply With Quote
Old 03-10-2014, 08:19 AM   #18
92R32GTST
92R32GTST's Avatar
I'm bias with rb I'll hang on to it lol. I already have rb25 swapped 240z lol. Plugs all gapped at .08
Old 03-10-2014, 08:22 AM   #19
Cronus577
Cronus577's Avatar
JESUS, .08?!?!? Is it boosted?!
Old 03-10-2014, 08:27 AM   #20
s14-rb20det
I respect your opinion, just to let you know I have my rb20det for The pass five years with the precision 6262 500hp on 23psi and I never have a problem. But that me.[IMG][/IMG]
Old 03-10-2014, 08:31 AM   #21
Cronus577
Cronus577's Avatar
No no don't get me wrong, the motors are tough but the on I had only had power at 5-6k+ rpm. They're just way too heavy to justify the weight of it and amount of power it made
Old 03-10-2014, 08:50 AM   #22
92R32GTST
92R32GTST's Avatar
That's awesome^ 6262 all day!
Old 03-10-2014, 01:27 PM   #23
92R32GTST
92R32GTST's Avatar
It's a rb20det so yes lol.
