I owe on some stupid back registration fees and need money asap... so time to clear out old parts! Im pricing everything to MOVE FAST. WILL SHIP!! and work out deals Will post more as I clean deeper thru the garage For fastest reply please text 714 305 4895 feel free to ask any and all questions! -750cc percision/msd style top feed fuel injectors. SUPER low miles. Trimmed to fit nissan style manifolds $sold -350z Nismo style rear wing. Fits 240 as well. Sitting collecting dust $40 what it looks like installed/painted -OEM s15 hood hinges. Good shape. i used on my s13 to s15 conversion $30 -OEM style (made of fiberglass) s15 hood. Has damage visible damage on underside that has been repaired. Top is ok shape. Has some waves in fiberglass and holes in paint. Has hole where screamer pipe dumped. Red sparco hood pins. Hood in this pic $75 - Defi BF (blue face) Racer (independent. no need for control unit) Water temp gauge in deg F. Missing sensor and Black trim. AUTHENTIC. Works perfect. Face of gauge is perfect. Still turns on without sensor just reads 0 $sold -Ka24e Oem timing chain kit. Brand New from frsport. Dont trust the ebay kits when u can get this... $solllld -Takata New gen style harnesses reps?...But perfect reps $150 each or $250 for pair -Takata Tow strap. New.. Replica? Have a green and a black $30 -F1 flywheel. Lightweight and worked great. Has about 1k miles but mostly track miles so it looks more used then is. No cracks or issues. Get a $25 resurface and save yourself a ton of money. $50 -Exedy stage 1 clutch. for ka24(e/de) Basic upgrade over stock. Has about 1k miles but mostly track use. No issues. Clutch cover painted ricer blue. $40 -AFCO large racing radiator. Brand new in box. Perfect for custom swaps and higher powered engines. Can work with ka / sr with modifying hoses driver side ports. This is a real racing radiator. Far superior to koyo/mishimoto $sold -j30 maf. Basic cheap plug and play upgrade $40 -Custom and factory rebuilt holset he351ve VGT turbo. No shaft play. Internals are essentially brand new. This is the future of turbos. look it up.... quickest spool with maximum air flow. I deleted electronic control and is ran off regular wastegate Will make a separate detailed thread on this later. inquire for more info. $500 -Sparco One Piece Racing Suit. Yellow/Gold with blue stitching. Retro as fuck. Period correct looks... Worn once basically new. 86' FIA Standard Certification. Size 54 (medium/Large) im 6'1" about 150pounds. Made in Italy $200
Braaap Last edited by zeebrah; 05-20-2015 at 01:20 AM.. |
the bottom of injector that seats into the manifold and sprays into the cylinder had like 1 mm of material taken off with a dremel. The way the injectors come the cone that shields the nozzle is too big to fit. Text me for more info specific pics!
Braaap |
| defi, drifting, racing, s15, takata |
