![]() Join Date: Mar 2013
s14 creeking the passenger rear wheel? help
https://www.youtube.com/watch?v=UtCfiTvF96c
does it the most when im turning tight and i took the wheel off and the rotor seems loose idk if that has anything to do with that but if you could take a look that would be great. |
![]() Join Date: Dec 2012
Thats a lil weird.. If u close the windows and drive at a moderate speed do u hear a humming sound?
But mostly sounds like your brake pads? the rotor is held in by the lugnuts ,so if u remove the wheel the rotor does get loose with a tap or push |
