![]() Join Date: Aug 2010
Trader Rating: (38)
Spark Plugs for KA24DE/T
so i've been lookin around for spark plugs for the motor i just rebuilt. it's na atm, but i plan to be turbo hopefully by august.
now i saw fr sports has these: NGK Iridium IX Spark Plugs Nissan 240SX KA24DE Turbocharged Colder and there is a stock-mild range. i plan on only making 200-250whp. is that considered stock-mild? if that would be considered mild-high, would the mild-high spark plugs be ok to run on my stock motor? or would it cause it to run properly? because it says it's gapped for force induction, so i'm not sure if it would be alright for n/a. thanks in advance. |
![]() Join Date: Dec 2005
You really don't need to go with iridium, copper cores will work just fine. Turbo motors eat spark plugs like a fat kid eats cookies, so why spend a boat load on plugs every time? Just make sure you get the right heat range and gap em correct and an NGK copper core plug is all you need
