Precision turbo specials @ PSI PROformance
PSI Proformance is a stocking dealer for precision turbo products, we carry the full line from turbo's to wastegates stocking most billet 5857,6262,6765,6266, as well as the entry level line send an email to [email protected] for the best pricing on precision products
Get your billet turbo's as well as direct bolt on turbos for anyone running the stock t25 flanged setups Precision Turbo and Engine is proud to introduce our line of direct-fit upgrade replacement turbochargers with the unique CEA (Competition Engineered Aerodynamics) 2618-forged aluminum compressor wheel. These turbochargers are specifically designed to out-perform turbos of the same size from other suppliers while delivering greater efficiency and less turbo lag. PTE's Direct Replacement Performance Upgrade Turbochargers feature the following: • Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging • Liquid-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) • Higher efficiency and faster transient response for maximum power and performance • 51mm inducer compressor wheel • Compressor cover options: - "B" compressor cover 2.8" inlet/2.0" outlet - "E" compressor cover 3.0" inlet/2.0" outlet • 53.8mm, 76 trim turbine wheel • Turbine housing options: - T25 .64, .86 A/R wastegated - T3 .48 A/R with 5 bolt discharge (with wastegate hole) • Wastegate actuator included with "B" compressor cover and T25 housing
Dyno Tuning-Engine Swaps-Engine Building-Turbo Kits-Fabrication-General Repairs-State Inspection& Emissions-
PSIPROformance 200 w 5th St (Unit D) Lansdale Pa 19446 215-361-7100 www.psiproformance.com |
Pmed you ....
had some interest in a group buy... stay tuned
bump.........
who would be down with a group buy?
Pmed you ...
pmed you aswell
pmed you ...
Pmed you Casman
#20 |
pmed you ......
#21 |
![]() Join Date: Jan 2010
precision 5431 CEA to 95747 please!
im looking for 350-400hp with a little room to grow and full spool by 4k-4.25k on my 1.9L bp miata motor (e85, forged bottom end, etc), i have the right one, correct? from what i have read, the srt4 guys like the budget cea lineup a lot. |
#22 | |
pmed you a price ![]()
#25 |
they will be fulfilling back orders next week
#27 |
Pmed you .....
#28 |
bump.......
| 240sx, 2jzgte swap, precision, tuning, turbo |
