![]() Join Date: Feb 2002
![]() When the injectors and fuel pump are upgraded to a larger flow setup the stock fuel pressure regulator will not be enough to suit the required pressures for the new setup. Also the stock is already preset to from factory for the standard setup and non adjustable so it will be restricting the tuning potential of the car. The TOMEI Fuel Pressure Regulator will ensure stable pressures are supplied with the oversized diaphragm. This special design has proven to maintain the required pressure levels with any adjustments made. Type S 185001 is recommended as factory replacement and increased fuel demands. Type L 185002 is recommended for very high hp applications with large fuel needs. Click here to order ===> http://www.enjukuracing.com/products...or-type-s.html
Why are they more expensive than anywhere else? Free shipping at least?
I need one and rather order from you guys. |
I can most likely do free shipping for you depending on where it needs to be shipped. If its in the continental US then it shouldn't be a problem. We don't ship to Hell though, lol! (your listed location)
