![]() Join Date: Dec 2007
Trader Rating: (63)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 63 reviews
How to get an extra Vacuum/boost source from Intake manifold
Ok, I got stock S14 SR20 intake manifold and need to get some extra Vacuum/boost nipple made to get dedicated source instead of using T fittings.
What would be the best way to make an extra vacuum nipple?? |
![]() Join Date: Jan 2011
Trader Rating: (26)
Remove the top plenum, drill it, tap it to the fitting you have(any ace, Home Depot etc has barb fittings), clean out any metal shavings from intake and put it back on
Edit-but a vacuum box seems like an easier route.
IG/TikTok-ThatS14_Z06guy
![]() Join Date: Nov 2010
Cuz i too was trying to reduce my "t's" Now if you have a greddy/freddy itm, they do include extra ports for additional vac lines on the bottom side.
#6 | |
Trader Rating: (63)
I like my stock intake manifold. I totally feel unnecessary to upgrade that. |
![]() Join Date: Jun 2007
However you decide to do it, just remember that your FPR vacuum line is the one thing you want to avoid tee-ing at all costs. I prefer a vacuum manifold... That way, I can keep my FPR line by itself on one side of the bay, and keep everything else on the other side with just one line going into the cockpit for my EBC & Defi link thru a firewall grommet. I have a FReddy intake, but keep all the additional ports plugged b/c I am not a fan of vac lines going across the bay. Also, like dude said above; if everything has its own port, there are theoretically less potential points of failure.
If you aren't comfortable tapping the intake, you can tap the hot and/or cold pipes. To answer your question above, you shouldn't need any sealant. I use thread tape on all my -AN & barb fittings; but I am sort of anal lol. Also, a rule of thumb I go by is to keep the FPR vacuum as close to the rail as possible, and the boost sensing/controlling lines as close to the source of boost as possible... Hope this helps~
#9 | |
if the source needs to see vac when the throttle body is closed.. then do not tap off of he charge pipes
