S14 front bearing help!!
Im in the middle of swapping my S14 to 5 lug. I got one of the front hubs done nor problem, everything bolted on great. But when I did the driver side I used a hub puller to get the hub off, but part of the bearing broke off and is stuff on the spindle. I might just try cutting it off, but Im nervous about damaging the spindle by doing that.
Does anyone have any suggestions?! |
![]() Join Date: Dec 2002
If the bearing came apart, it was bad. There isn't any need to use a puller to remove them. Since you now know the bearing was bad, it's likely the spindle was damaged as well from the bearing race grinding against it, being that it's stuck it's fused on from heat.
#3 | |
