Closed Thread
Old 09-05-2010, 02:06 AM   #91
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
Build is going good pat! I got the diff out of that z32
You still in mobile?? We are doing Justin's SR at my house and he told me you guys ran into each other randomly last week.
VQMaxFan is offline
Old 09-05-2010, 10:25 AM   #92
Sileighty_85
Sileighty_85's Avatar
Sup man, Thanks, haha nice if i had more room in the S14 i would have snatched a lot more parts lol
Nah i left last week, yeah it was pretty crazy, I meant to call ya'll but seemed like I didnt have enough time, im ususally pretty busy visiting with family and shit.
Wish i was there to help man, i hope it goes smooth
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Sileighty_85 is offline
Old 09-05-2010, 11:24 AM   #93
GSXRJJordan
GSXRJJordan's Avatar
Originally Posted by Sileighty_85 View Post
next will be the MAFS section.....sighhhh Fuck you JDMONLINE.COM.......
I have some Mil-spec M27500 two-conductor shielded wire that I use to extend MAFS and CAS, want me to send you 8 or 10 ft?
GSXRJJordan is offline
Old 09-05-2010, 01:46 PM   #94
Sileighty_85
Nah man dont worry about it, I'll just go to a junk yard and and delooom a J30 MAFS cable haha.
Not even 100% sure im even gonna use this harness, Kinda afraid to use it due to the condition (not having the physical plugs to verify the correct wires. I got to go off of colors and tracing back to the ECU pinouts) and wiring guides Ive found and used.
Traced back the unknown wires to found out they are not important (Exhaust temp light and ABS related)
I think i have all the grounds as well, Couldnt find anymore loose wires, So I guess there is only 3 grounds.
後輪駆動車1番
1986 SR86 - 200ish
Old 09-05-2010, 03:51 PM   #95
Sileighty_85
Since I gotta wait for a junkyard to open, Im gonna wok on the lower harness
once again JDMONLINE.COM are a bunch of lying bastards
De-Loomed
So apparently I can use the Lower KA harness
And the Knock Sensor section is the only section that I need from the RB lower harness minus the Oil Pressure plug, and possibly the Tranny plugs and a swap of the Starter Solenoid plug
If anyone wants to know here are my References that im using
後輪駆動車1番
1986 SR86 - 200ish
Old 09-06-2010, 12:47 AM   #96
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
with the nismo tranny mount that you used , the z32 mount. is it because you have the rb25 tranny ? or do you have to use the z32 mount cause of the s14 chassis ?
i would like to get a nismo tranny mount for my car but i donno if i should use the s13 or the z32 mount .
1992 240sx (RB20. [email protected])
eklips3 is offline
Old 09-06-2010, 01:05 AM   #97
Sileighty_85
I used the Z32 cuz its the same style as the RB25 tranny
Its beefier than the S13 one
後輪駆動車1番
1986 SR86 - 200ish
Old 09-06-2010, 01:21 AM   #98
Om1kron
Om1kron's Avatar
I'm all about removing the knock sensor from the equation. LOL But I guess now that my motor is running right It wouldn't hurt for me to put it back on.
Wayne
Om1kron is offline
Old 09-06-2010, 10:35 AM   #99
kingston240
kingston240's Avatar
kingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond reputekingston240 has a reputation beyond repute
if you ever tune your car, the knock sensor is a huge one.
its not something i would leave out.
www.facebook.com/HellaFab
kingston240 is offline
Old 09-08-2010, 06:04 PM   #100
VQMaxFan
VQMaxFan's Avatar
Tried to get the pinout of your 98 to compare it to the diagram you have now but the computer with the nissan fsm's on it wont load any esm's for some reason. (infiniti & nissan)
VQMaxFan is offline
Old 09-09-2010, 12:14 AM   #101
GSXRJJordan
Lol the factory knock sensor is two steps away from totally worthless. If you're using it to tune your car, you need to stop and contact a pro.
Also, standalones don't use the oem knock sensor, so no one with built motors uses them either.
Old 09-09-2010, 02:23 AM   #102
Om1kron
Om1kron's Avatar
And that horn you hear honking is the school bus. BAM
Wayne
Om1kron is offline
Old 09-09-2010, 09:06 AM   #103
Sileighty_85
All the post and pinouts I've found, they are saying they are the same (or similar) as the 96 with a different wire or two, but from the pinouts ive posted and the ones Im finding they are matching up the same
後輪駆動車1番
1986 SR86 - 200ish
Old 09-10-2010, 11:35 PM   #104
eklips3
eklips3's Avatar
do you know if the z32 mount will fit on the rb20 tranny ?
eklips3 is offline
Old 09-10-2010, 11:48 PM   #105
Sileighty_85
I THINK so, When i was researching mine I think i compared it to an SR one (same as the RB) and they were the same
後輪駆動車1番
1986 SR86 - 200ish
Old 09-11-2010, 01:44 AM   #106
mrflip69
mrflip69 is an unknown quantity at this point
Haltech Platinum Pro uses OEM knock sensor. I think the new AEM series use it too--Nistune obviously.
Plenty of people run PFCs without knock control though...
If you've got a good tuner, it shouldn't be a problem, but I figure it's always good to have an extra fail safe for those hot days and extra crappy gas.
I'm more interested to see you fit all the AC/rad/fan stuff though, as there's barely any room with my setup--but S14 has just a bit more room than an S13.
..before time was so cool.. when people built long-term personal cars..
mrflip69 is offline
Old 09-11-2010, 12:30 PM   #107
Sileighty_85
So I had to work today so I figured I'd make the best of it.
I didnt like the solder job (shitty solder iorn) and the heat shrink (too big)
So i redid it. I guess one perk of my job.
Finished again.
後輪駆動車1番
1986 SR86 - 200ish
Old 09-11-2010, 04:01 PM   #108
Sileighty_85
Hit up the Junk yard for some plugs and wires today.
Got the Z32 Shielded Wire, A Kouki Wiper plug from a (EDIT) Infinity I30 and a MAFS for the RB Series I plug from the I30 as well
Im quite surprised I found a plug that will fit on the RB Series I MAFS but the problem is the pin out id differnet from the RB MAFS pin out so you gotta repin it. (Not hard at all)
Has this weird/cool connector on it
後輪駆動車1番
1986 SR86 - 200ish
Last edited by Sileighty_85; 09-14-2010 at 12:07 PM.. Reason: Car Make Edit for the plugs
Old 09-11-2010, 09:54 PM   #109
xiaphin
Trader Rating: (32)
xiaphin is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to xiaphin
Never seen a Nissan connector like that before. Weird
2018 Audi RS 3 | Unitronic Stage 1 ECU and Stage 2 TCU tune
xiaphin is offline
Old 09-11-2010, 11:23 PM   #110
sleeper108
sleeper108 is an unknown quantity at this point
you're a far braver man than I.
After I cut a wire, and my car didnt start for a year, I swore to never touch another harness again lol.
Can't wait to see you get everything all in and wired up!!!!
sleeper108 is offline
Old 09-11-2010, 11:47 PM   #111
singlecamslam
nice work bench, got my rb25 running and loving the noise it makes.
singlecamslam is offline
Old 09-11-2010, 11:49 PM   #112
NewYorkCoupe
NewYorkCoupe's Avatar
NewYorkCoupe is an unknown quantity at this point
Send a message via AIM to NewYorkCoupe
Glad to see you are pullin through on the wiring. That was my winter project and it was a bear. I sat down and spent 10hours planning everything and cut/soldering. I swore Id never do it again, but after hearing it start up for the first time Id take back every swear-word I said while wiring.
NewYorkCoupe is offline
Old 09-11-2010, 11:49 PM   #113
Om1kron
Om1kron's Avatar
because if you read his post you would've seen he pulled them from an IS300 you know TOYOTA. They fit into the oem plug sockets. Most japanese car makers use the same plug manufacturer for their harnesses, so he lucked out finding those parts on a different make, good to know some Toyota plugs can be adapted to the S-Chassis.
I dig your workstation, Jeff (GSXXRJordan) has a soldering station just like that, it's his favorite thing in the world.
Wayne
Om1kron is offline
Old 09-11-2010, 11:51 PM   #114
NewYorkCoupe
Any chance there was another donor IS300? My MAFS connector was broken beyond use, and if that one you got works Id gladly pay for the part + your time and effort.
Old 09-12-2010, 02:01 AM   #115
Sileighty_85
EDIT: Car was an Infinity I30, I was just searching through all the imports and stumbled upon these
Yeah that soldering station is the shit, I want one for my house. Waaayyyy better than those craptasic craftsman soldering irons.
Unfortunately that was the only one. If I come across another one Ill let you know
Man this wiring is gonna drive me crazy. I gotta make little notes to remind me what wires are what what where they go.
Well the Schematics are showing that the Series 1 is a 4 wire Plug but the MAFS has 5 pins, I guess 1 is not used?
but had to repin the connectors for the RB MAFS and the Kouki wiper motor (very easy took like 2 mins)
deloomed and installed the Z32 MAFS wires, Cant seem to find the MAFS 12V wire, but I think I found it, Its a small Bl/W wire, I guess cuz its small its throwing me off
New MAFS Wire
almost done, Just need the O2 Sensor and RB MAFS plug wired in and should be done..... :/
But there is also some square plug thats suppose to come from the MAFS section not sure what the hell it is, Wiring schematic says" Engine Room/H" Dont know what the hell that means
後輪駆動車1番
1986 SR86 - 200ish
Last edited by Sileighty_85; 09-14-2010 at 12:06 PM.. Reason: Car Make for the plugs
Old 09-12-2010, 02:51 PM   #116
NewYorkCoupe
If I was home I could help out with colors and whatnot. Keepin my fingers crossed for you, however, it looks like you are doing pretty well. Keep at it.
Old 09-13-2010, 12:03 AM   #117
buentellomma
buentellomma's Avatar
buentellomma is an unknown quantity at this point
nice work man, i hate wiring... your a brave man. are you military?
buentellomma is offline
Old 09-13-2010, 12:36 AM   #118
Om1kron
Om1kron's Avatar
probably just a diagnostics plug.
Wayne
Om1kron is offline
Old 09-14-2010, 11:58 AM   #119
Sileighty_85
I hope so lol
As a correction for the peeps looking for an RB MAFS or Kouki Wiper plugs the Car I pulled the plugs off of was am Infinity I30
Alright so I went to the junk yard today and picked up a Z32 O2 sensor plug
my awesome soldering station lolz :/
So now I THINK the RB harness is done....
後輪駆動車1番
1986 SR86 - 200ish
Old 09-16-2010, 08:40 AM   #120
fender-startocaster
fender-startocaster's Avatar
fender-startocaster is an unknown quantity at this point
in for updates!
fender-startocaster is offline
Closed Thread
rb25 install, rb25 rebuild, rb25 s14, rb25 swap
