![]() Join Date: Aug 2019
Please help with fuse box identification
Hi guys so I just rebuilt an sr gettin ready to put it in my 1989 240sx but before I do i wanted to put the car in accessory to make sure the windows roll down at least or I have some sign the car electronics work. Where would my positive cable connect to on the engine bay passenger side box? Also on the driver side ACC fuse box I think someone before me cut the ground wire off it.. ive attached pictures to make it easier if someone can help that would be much appreciated! Edit: I know the bigger of the two electrical eyelets on the engine bay passenger side box run to battery+, alternator +, and starter +, what would be the best way to fix that driver side ACC fuse box ground is my real question?
https://ibb.co/vjtsDFT https://ibb.co/0Z4CrTS https://ibb.co/VBCN2VZ Last edited by Dsmguy1993; 01-02-2020 at 10:30 AM.. |
Thank you kyral! I kinda figured it was just lookin at it for a while i already tested my wiring specialties interface harness that plugs right into the box and the box also has a connector for the Alternator charge harness ima wire it up after I quit being lazy and take the hood off.
I got the car to come onto accessory again just grounded the fuse box using sand paper hooked a battery up connected to the fuse box larger white wires connection and it works brake light switch is bad because brake lights stay on. Clock comes on dash lights come on still.
![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
The Game you lose haha |
