***NOT LOCATED IN CALIFORNIA PLEASE STOP ASKING FOR PICK UP - SORRY***
I have the following things (used) for sale with application to the S14. Prices are firm, low balls will be ignored. Prices do not include shipping cost. IF you have a serious intent on buying an item I will take pictures for you personally. Thanks. Z32 Rear Drum Brakes + Project Mu Disc Pads - $200 SPL Camber Arms - SOLD SPL Toe Arms - SOLD SPL Traction Arms - SOLD S14 OEM JDM Kouki Wing - SOLD Trunk Lid 3rd Brake Light Shaved - $100 S14 JDM Kouki Taillights - SOLD Driveshaft Shop 1 Piece Aluminum Driveshaft - $200 Nardi Suede 350mm Deep Corn Black/Red Stitch Steering Wheel - $200 Nismo Motor & Transmission Mounts - SOLD Welded Diff w/ 4.3 Ring & Pinion - $100 KA24DE Megan Headers + Flex Pipe + Test Pipe - $300 Megan Track 12k/10k Coilovers - $400 Sparco Hood Pins (BNIB) - $30 Rear Subframe w/ PSM Solid Risers & SPL Solid F+R Diff Bushings - $300 URAS Type 4 Kouki Body Kit - SOLD PSM 10mm Slip-ON Spacer - $50 Bolt-ON 15mm Spacer - $75 OEM S14 Kouki Corner Lights + Super Bright White LEDS - $100 ***PICS*** ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by lflkajfj12123; 11-23-2014 at 01:54 PM.. |
#6 | |
Nismo Motor Mounts - SOLD I have received A LOT of messages (30+) about these parts so please bear with me while I take things off the car and get you pictures. If you really want something offer me higher than the prices listed and your priority gets moved to the top. |
Posted some pictures!
I replied to some PM's and will be going through more later. I spent the day taking parts off and will continue over the weekend. I've seen your message... I'm just working on getting you pictures. Thanks everyone for their patience. I will not be texting anyones numbers so please use the private messages on here. Everything will be shipped with FedEX ground and professionally packaged. |
#30 |
nardi still available?
