![]() Join Date: Sep 2011
Trader Rating: (18)
Ok guys I need help, I'm having a very similar problem to this guy here: http://forums.nicoclub.com/injector-...p-t317319.html
And I'm not sure what the problem is. I took off the fuel rail and turned the car to the "on" position and gas is shooting out of injector #1 and #4. My motor is a stock redtop sr20det just completely rebuilt and hasn't ran yet. Any help is appreciated. I did search but most threads yielded no results. |
If the same thing happens with the injectors unplugged, it's probably leaking around the O-rings. If it only happens when the injectors are plugged in, check the wiring from the injectors to the ECU. If they are shorted to ground, the injectors will stay open all the time.
NismotronicSA - Speed-Density Tuning for Nissans |
#4 | |
Trader Rating: (18)
GM2 (SW/AW)
Just to piggy back on most of the replies, MAKE SURE, your O-rings aren't pinched to the point where they're either broken or separated.
