Fan Shroud
this might be a really stupid question, but i tried searching and couldnt find the answer. im swapping the sr20 into my s13 and i was wondering if the ka fan shroud will mount up or will i need an sr20 fan shroud? radiator is an sr20 koyo. thanks in advance
![]() Join Date: Feb 2004
No it will not work, even if you make it fit it will be off center requiring you to make custom radiator hose. Searching would of netted you those answers...
The s13 sr20 is a 1 peice design so don't worry he can't fail in that department but to add to the OP's question no the ka shroud won't on a sr20
Instagram username:angelmkiv |
![]() Join Date: Jul 2005
also close the gap around the sides. the fan shroud fits nice, but it sits away from the radiator far enough to leave a gap around the sides.
the OEM shroud on a factory 240sx has little plastic side panels to fix this. |
