Cutting Out Problems
Car:
S14 with SR swap Problem: -Car cuts out at certain rpms -Cannot drive past 30mph Things I have done already: -Changed out MAF and checked wiring -Checked wiring for O2 -Checked sparkplug gap Any help is appreciated, thanks ahead |
Clogged fuel filter maybe?
NismotronicSA - Speed-Density Tuning for Nissans |
#4 | |
![]() Join Date: Dec 2012
![]() One tip ive heard is to spray some "maf cleaner or brake cleaner " in the intake system NOT directly at your maf, and if the idle rises and stays smooth for a bit then its fuel related. |
The car idles fine and drives fine untill I hit a certain rpm. For first gear its around 6k. Second its around 3100. Third its around 2100. I've already checked for boost leaks
This guy has the same problem but theres no answer. He describes it pretty well
http://forums.nicoclub.com/help-240-...m-t542441.html |
I have no idea what to do now so I pulled the plug on the maf and it threw code 12 which didn't surprise me but it did also get rid of the cas code. Also I read up that the vss can cause this sort of problem?
Glad you found it!
